SEMA 2006-NOS Energy Drink SC300
I CANT BELIEVE I JUST WASTED THAT AMOUNT OF TIME WATCHING THAT
All i have to say is WOW.. does this dude really think no one will see this who knows whats up?
-first off the car isnt from a junk yard.. it was bought about 30 mins south of DC from my freind, for cheap, but it was a beat down car, but a driver none the less.
-one off door? NO
-13k 6 speed? hahaha
god i could go on forever.. I saw him on an interview on TV at a nopi show saying it was a 2JZ gte hahaha
Please dont let this guy and his interviews take anything away from the shop who totally built this car MA-MOTORSPORTS... they are a bunch of bad *** guys who really know their **** and build awesome stuff..
this guy has no idea whats done to the car or the amazing craftmenship that MA did...and the MA guys know this too , no doubt
sorry to see this.. and especially sorry to know that the car will never see the road.. let alone a drift event
-one off door? NO
MA built the car but I have ordered parts from them for my 240s. It was posted on other sites before clublexus. I'm pretty sure I seen it at Nopi Nationals make a horible appearance. Lets hope somebody soon can drive it right.
Its around 10k in parts to swap an auto to a 6spd.
http://www.mkiv.com/techarticles/au...swap/index.html
Engine drive belt tensioner assy:
http://mkiv.com/techarticles/auto_t...tension_damper/
16620-46070 tensioner list 196.17 cost 145.07
16621-46010 bracket list 40.41 cost 29.89
16622-46010 arm list 19.26 cost 14.24
16602-46010 shock absorber list 62.56 cost 46.26
91511-g0845 bolt list .91 cost .68 x 2
90901-16001 stud list 2.09 cost 1.54
90179-08171 nut list .89 cost .65 x 2
90116-08348 bolt list .83 cost .62 x 2
90080-17242 nut list 1.37 cost 1.01 x 2
parts total : 242.92
Clutch parts:
90363-12002-77 pilot bearing list 8.76 cost 6.48
96152-00500 snap ring list 2.66 cost 1.97
90903-63001 t/o bearing list 65.50 cost 48.44
90560-50001 snap ring
90560-79001 spacer list 2.31 cost 1.71
90206-12006 wave washer list 1.57 cost 1.17
90520-75001 snap ring list 2.97 cost 2.20
31264-14060 spring list 2.97 cost 2.20
31231-14050 hub list 33.38 cost 24.69
31204-14060 fork list 65.16 cost 48.18
31234-14020 spring list 1.97 cost 1.46
31236-14030 support list 31.27 cost 23.12
90119-08079 clutch cover bolts list .46 cost .33 ea x 6
90119-10054 bolt list .86 cost .64 x 2
90910-02115 flywheel bolts list 9.72 cost 7.18 ea 8
13450-0W011 flywheel list 611.96 cost 452.53
Use your own supplied clutch cover and disc. See up-grade list at the end of this post for the TRD single disc or TRD twin disc kits.
parts total : 674.85
Transmission:
33030-0w212 v160 assy new list 5478.75 cost 4774.12
31123-14020 inspection cover list 29.84 cost 22.07
31121-14030 inspection cover list 36.18 cost 26.75
90080-11228 bolt list .69 cost .50 x 4
08885-01306 v160 oil qt list 47.62 cost 35.21 x 2
Transmission comes dry shipped, no fluid.
parts total : 4895.36
Clutch Hydraulics:
http://www.mkiv.com/techarticles/au...side/index.html
31470-14060 slave cylinder list 64.61 cost 47.77
90080-10055 bolt list .89 cost .65 x 2
31410-14310 master cylinder list 99.39 cost 73.49
90179-08237 nut list .91 cost .68 x 2
31481-14260 tube list 20.52 cost 15.24
96816-50335 hose list 24.86 cost 18.47
31484-24010 bracket list 6.69 cost 4.97
31482-14060 tube list 10.89 cost 8.06
90119-06406 bolt list .69 cost .50
96991-10080 clip list 1.20 cost .89 x 2
90119-06733 bolt list .54 cost .41
90080-11231 bolt list .51 cost .38
90461-08702 clamp
79191-00502 Castrol GTX brake fluid pt. list 3.75 cost 2.50
Braded TRD clutch hose available, see up-grade list at end of post.
parts total : 176.23
Transmission mounting/driveshaft
12371-46110 trans mount list 70.56 cost 52.18
90119-08770 bolt list .89 cost .65 x 4
90179-08159 nut list .89 cost .65 x 4
90201-11013 washer list .52 cost .38 x 4
90179-11017 nut list 1.51 cost 1.12 x 4
37100-14810 driveshaft list 675.26 cost 499.33
90119-10217 bolt list 1.51 cost 1.12 x 2
90105-12265 bolt list 7.63 cost 5.65 x 3
90560-12059 spacer list 4.12 cost 3.04 x 3
90179-12128 nut list .91 cost .68 x 3
TRD trans mount available, see up grade list at end of post.
parts total: 593.06
Shifter assembly:
http://www.mkiv.com/techarticles/au...6spd/index.html
33504-14130 shift **** list 103.63 cost 76.63
33511-14031 control shaft list 25.15 cost 18.60
33513-22030 yoke list 7.63 cost 5.65
33530-14442 93.5-95 short throw shifter list 126.44 cost 93.49
90301-11015 o ring list 2.92 cost 2.15 x 4
33531-14010 boot list 39.44 cost 29.16
90387-08134 collar list 1.91 cost 1.41 x 2
33555-14110 boot list 31.55 cost 23.33
33555-14100 boot list 9.83 cost 7.27
33556-14050 seat list 1.54 cost 1.14
33057-14010 bracket list 44.33 cost 32.78
33570-14070 shifter tri-pod list 96.77 cost 71.56
93381-16016 bolt list .85 cost .55 x 4
90179-08095 nut list 1.14 cost .85 x 2
90105-08200 bolt list .89 cost .65 x 2
91651-60835 bolt list .26 cost .20 x 4
90105-08076 bolt list .74 cost .55
90179-08233 nut list .91 cost .68
90250-06026 pin list 1.06 cost .79
90467-21010 clip list 2.61 cost 1.93
33546-22020 bushing list 14.15 cost 10.47 ea x 2
You can use the B & M shifter in place of the stock one.
parts total : 380.98
Console parts:
http://www.mkiv.com/techarticles/au...nnel/index.html
58261-14010 upper trans tunnel list 78.54 cost 58.08
58994-14010 console bracket list 6.74 cost 5.01
91651-60614 bolt list .94 cost .71 x 2
58804-14060 shift bezel w/boot 93.5-96 list 140.44 cost 103.85
58804-14100 shift bezel w/boot 97-98 list 140.44 cost 103.85
58280-14080 boot/plate assy list 23.81 cost 17.60
parts total : 168.36
Brake pedal:
47101-14230 brake pedal list 49.67 cost 36.88
31321-14020 brake pedal pad list 3.23 cost 2.39
You can re-use the misc parts on the brake pedal bracket assy.
parts total: 39.27
Electronics:
83242-1u310 6spd tach list 118.75 cost 88.19
89661-14521-84 ecu 6spd obd1 93.5-96 list 1111.50 cost 913.53
{includes 100.00 core charge]
Call for obd2 ecu pricing.
If Dusty @ MVP has them available you can use the TRD 10K tach.
http://www.supraforums.com/forum/sh...threadid=181819
parts total : 1001.72
Clutch pedal:
31311-14120 clutch pedal list 42.18 cost 31.32
90541-06036 cushion list .83 cost .62 x 2
90949-03011 spring list 1.93 cost 1.43
90386-13015 bushing list 1.37 cost 1.01 x 3
90949-03013 spring list 11.40 cost 8.47
31321-14020 pedal pad list 3.23 cost 2.39
90101-10015 bolt list 1.00 cost .74
90387-10003 collar list 4.54 cost 3.36
31353-14010 holder list 3.34 cost 2.47
90240-08006 pin list 1.71 cost 1.27
90386-08010 bushing list 5.37 cost 4.00
55107-14140 support assy list 69.76 cost 51.80
91655-60630 bolt list .60 cost .47
90119-08a22 bolt list .71 cost .53
96160-00600 e ring list .63 cost .47
94512-01000 washer list .63 cost .47
94110-51000 nut list .60 cost .47
90386-05017 bushing list 1.91 cost 1.41
90206-08001 washer list .83 cost .62
90468-16142 clip list .72 cost .53
88280-14030 switch list 16.60 cost 12.32
84520-24010 switch list 38.64 cost 28.68
94120-41000 nut list .60 cost .47
parts total : 157.96
Rear differential:
http://www.mkiv.com/techarticles/au...tial/index.html
41651-14010 mount list 81.14 cost 60.00
41110-14780 6spd lsd diff assy list 2563.80 cost 1895.85
79191-00672 75w90 Castrol gear oil list 13.95 cost 10.15 x 2
42340-14140 lh drive axle list 393.49 cost 290.97
Diff comes dry, need to fill.
Up-grade to TRD LSD UNIT see list at end of post.
parts total : 2267.12
GRAND TOTAL:[ for those of you who don't know how to use a pocket computer or are to lazy]
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
10,597.83 SHIPPING NOT INCLUDED
Thats without labor
http://www.supraforums.com/forum/sho...d.php?t=211926
aight peace
Clutch parts:
Transmission:
Clutch Hydraulics:
90461-08702 clamp
parts total: 593.06
Shifter assembly:
Console parts:
Brake pedal:
parts total: 39.27
Electronics:
Clutch pedal:
Rear differential:
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
Thats without labor
aight peace
imo i dont like that car that much. i think if ur going to build a true sick SC for show that will be feature nationwide if not world wide, its a shame ur putting on an Origin kit. everyone knows VS and Origin pretty much just knocked off Vertex. he doesnt even have sidemarkers on there. i swear i read in super street or another mag about the car and it had a Torque Converter??? i think its auto.
well the car was an auto. it might have been converted. but i did read somewhere in a magazine that it had an upgraded torque converter. maybe thats why he couldnt drift it cus its auto.
Clutch parts:
Transmission:
Clutch Hydraulics:
90461-08702 clamp
parts total: 593.06
Shifter assembly:
Console parts:
Brake pedal:
parts total: 39.27
Electronics:
Clutch pedal:
Rear differential:
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
Thats without labor
aight peace
Clutch parts:
Transmission:
Clutch Hydraulics:
90461-08702 clamp
parts total: 593.06
Shifter assembly:
Console parts:
Brake pedal:
parts total: 39.27
Electronics:
Clutch pedal:
Rear differential:
242.92
674.85
4895.36
176.23
593.06
380.98
168.36
39.27
1001.72
157.96
2267.12
_______
Thats without labor
aight peace
Even so, add labor at a performance cali shop price, and now add money for 2k dollar clutches to handle single supra power like the one in my 6speed.
I saw this guy at formula D. He said his car made 700 hp on 4 bars of boost... The turbo looked like a 61mm. I can't believe they sponsored this guy. He's nothing but a joke. The fitment on that kit he has is horrible. The whole way his car is setup nasty.
I have seen this car in person at a couple Nopi events. I saw it at Rockingham awhile back and he actually brought the car onto the drift course setup, he got out and said to the crowd "who wants to see this thing drift!" Everyones screaming to find out he says a couple seconds later that Im sorry the car is not ready, it needs a lil more work.
I was almost disgusted, thus making me hate the owner.
I then saw it at Nopi Nationals this year, and he took it out at the drift event, and I actually missed him drifting. He supposedly did drive it on the course for a minute, lol.
The car looks good in detail, in person. But the owner does not give the props needed with a car like that to the people that deserve it.
Straight from MA-motorsports website:
http://www.jdmfresh.com/gallery/NOSSC300/index.html
