SC- 1st Gen (1992-2000)
Question about SC seats
Old 12-10-06, 02:48 PM
dondons_sc
dondons_sc's Avatar
Unhappy Question about SC seats
Can someone give instructions on how to take out the passenger side seat. I dont know what the seat is stuck on but the left side of the seat will move but the other wont. Now I wasnt sure if the sc seats have two motors on each seat or just one and if I have to how much will it cost to fix this myself. I wanted to clean my cabin air filter but cant get to it cause the seeat is stuck to the front of the car. Any tips?
Old 12-10-06, 03:36 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
there is only one motor, but it's weird how it drives both sides - hard to explain...
but... to get it to move manually, get a 10 or 12 mm socket with a 12" extension.... lay your head on the front floorboard and look at the underside of the seat.. on top of each sliding rail, you will see a nut... turn it with the socket and the seat will move forwards or backwards...
Old 12-10-06, 03:44 PM
dondons_sc
dondons_sc's Avatar
Thanks ill try it right now
JspecSC3
JspecSC3's Avatar
Its really simple. There are only 5 bolts you have to take off. 2 in the front of the rails and 3 in the back side of the rails and thats it. Once you remove all 5 you have to unplug the connector that is located right underneath the seat.
Old 12-10-06, 05:23 PM
dondons_sc
dondons_sc's Avatar
I tried it on the side that was stuck, but it didnt move the other side did so do you think ill have to take the seat out to fix it?
Old 12-11-06, 07:21 AM
Lbocpe
Lbocpe's Avatar
mods please help i've had this problem 4 two years!!
Old 12-11-06, 07:54 AM
mitsuguy
mitsuguy's Avatar
yes
you'll have to fanagle the bolts that are under the sliders... good luck... ratcheting wrenches are your friend
STDave
GX - 1st Gen (2003-2009)
08-20-15 07:19 AM
Stickyiqqy
02-13-14 12:57 PM
7akata
08-13-11 08:08 PM
ekrebs
09-17-08 10:19 AM
Aristo300
10-30-05 07:32 PM
Quick Reply: Question about SC seats
