SC400 Transmission Fluid
Please specify your SCs
How often do you change your trans. fluid?
Did anybody went over 30K miles between trans. fluid change?
I had a shake, run over rumble strips like, when the car at constant speed and only need a light acceleration. After changing the fluid. Problem gone
SC400 need special trans. fluid from Toyota
SC300 used regular Dextron II
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
trancez
Performance & Maintenance
10-15-08 07:47 PM
93, atf, capacity, change, changing, fluid, lexus, oil, replacement, sc400, service, tranmission, trans, transmission, type
