after me sc3 accident horn stopped working
after my accident horn stopped working
so as some of you guys know my sc3 was in a accident recently .now since i started driving it the horn stopped working .the cruise control dont even turn on anymore and the battery dies when parked for a couple days .is there a wire that control this under the driver side wheel well? .that is the only place i think the problem can be .
What type of battery? If its an oddessy, they all die after a couple of days, and if thats the case then check fuses. If thats not the case then i have no idea. Very bassic response, i know.
well its not the wires under the wheel .bought a new battery and it died after a couple of days too .is there a possibility the steering wheel turned too much and broke the wires in the steering wheel ?i'll take a look at it later on today .i miss my horn so much
you have an amp draw somewhere the best way to fix that is to hook up your amp meter to the neg batt cable while it is disconnected and use the ampmeter to jumb from the cable to the batt then start pulling fuses until your amp draw goes down and that will tell you what circut it is. I dont know what kind of crash sensors they have but i would check them find the amp draw first post and let me know what it is
fredgrube
SC- 1st Gen (1992-2000)
06-09-08 04:22 PM
