Clear/Red 92 Lights almost done
https://www.clublexus.com/forums/sho...d.php?t=229355
that's sc400on20's original write up
the rough edges will not be visible after i complete the last step, i just gotta find some time finish it..It is a simple yet time comsuming DIY and very easy to F up.
scoarer or sc400on20s? hopefully someone will chime in. anyways as i mentioned earlier im doing the same project. i was just curious what did you use to clean the epoxy that held the light together? I took both lights apart but it was quite a mess and i have some of the grey epoxy on the inner lens that i want to clean. should i use acetone? or is there another way to remove it? thanks in advance
try not to get the sealant on the lenses, but if you did get it in on a small area, I would say use a heat gun then wipe it off, and then use some acetone on it. Are you planning to clean off all the sealant? Because I just reused it when I put the light back together.
no i do not plan on removing it all. i just got a few dabs here and there on the inner lens and i was just wondering which would be the best way to clean it off. i also plan on using the original sealant to close up the lights
