SC max horsepower...
Does anyone know what's the maximum horsepower you can get out of a modified SC with every possible upgrade(twinturbo and all that good stuff)? And how much would it cost? So far the fastest I've seen is 500 something...
well the 2JZ-GTE motor (can be put into SC) has been pushed over 1000HP in a supra not an SC, meaning you would probobly have to do extensive transmission work (most likely a supra 6spd) to make that power in the SC
It is possible to do most anything to the engine. A single turbo will give you more power...the majority of high power supras/sc's are single turbo.
From what I've seen, 600hp seems to be the amount of HP that the block will handle safely. I've seen some cars running 700-800hp on stock blocks with no problems...but I would stay around 600hp to be safe.
If you give Toyomoto a call (305-599-3050) they can answer all your turbo questions for ya. I recently put their turbo kit on my SC, and it's awesome. Once I get over 600hp, I'm going to go ahead and upgrade the internals on the block, and make it a 3.3L stroker engine.
SR
SR
Originally posted by Bean
the gte long blocks can handle around 800-900rwhp before they need it... just depends on your setup, how well its tuned, etc
SR
