headlight removal help please
sry to be a pain, and i hate asking dumb questions, but how do i actually remove the headlights from the car? i have searched and the only thing i have found is how to clean them once they are out...
thanks,
vince
thanks,
vince
from the wheel well, take off the 10mm bolts on the fender lining, pull it back and reach in there. The two bolts you want to get are towards the outside of each fender and are 10mm, one is 3-4 inches above the other
You'll need a socket wrench extender, 6 inches long I think. A pain to get out the first time, but once you figure it out, it's easy the next time. If you have fog lamps, you might want to change them when the headlights are out even if they aren't dead. It seems easier to get to them with the headlight out than from underneath. Just my $.02...
Banned
great advice with the wheel!!!! now if you can jack up the front of the car as well then do it!!! --this way wheel will move downwards giving you more space to pull out that lining. then go n get those screws!! be careful so the light doesnt pop out on its own
unscrew top bolts last and remember of course about the bulb wires ( 3 )
vince1128, Step by step procedure on the headlight removal of an Sc with pictures. click on the link........http://web.ace.net.au/soarer/removal1.html
