Corner Weight Results (93 SC300) *Need someone to host pic in order to post results
Great info! Yes Darin is good at what he does. I highly recommend him to anyone in socal for a TRUE 4 wheel alignment and corner balancing. I expect to do mine in about 2 months after everythings installed. Also dropped off all my control arms to him to r&r bushings. Wow only 3400 lbs?! I expected at least 300lbs more.
![](http://img513.imageshack.us/img513/9611/img2143xxmb2.jpg)
This was taken in 2005
Specs...
92 SC300 2JZGE 5MT
Lightweight battery, HKS HIPERMAX-Pro Coilovers, 18" Volk TE37, Sun roof, Everything behind front seats gutted, Trunk gutted, No driver, I think half tank of gas.
Gonna do this eventually to my Supra will be interesting to compare.
was this done with the sway bars disconnected because that will definitely screw with your results. IF these numbers are right then the weight distribution is not that bad at all. some people bad in the day were saying its 65/35 but that seems way too nose heavy. toyota is better then that.
i think i need to go borrow some scales and compare.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
btw to the OP. the numbers on that sheet of paper are as follows:
1)corner weight
2)cross weight...thats the weight of the two opposite wheels(FL/RR or RL/FR). it is not the "quadrant" weight. quadrant weight would be the FL/RL/FR.
3) cross-weight being the percentage of total weight
4)section weights
5)total weight
1)corner weight
4)section weights
5)total weight
Rcreegan (07-26-22)
SC300 J
Wheels and Tires Classifieds
22
06-24-07 10:27 PM
troyb
SC- 1st Gen (1992-2000)
09-21-06 06:40 PM
