Hot Air!
Hi guys,
I have a 92 SC400.
It happened a couple of days ago.
I turned on the heater and no hot air was being pumped out.
The engine was at its normal operating temperature.
The coolant level is at its maximum level.
All the vents and settings are working properly.
I've read through the previous posts about this problem and saw that some of you guys made mention about a 'magnet valve' (?).
Where is this located? I want to check that out.
Also, it was stated that there is a hose that directs the air (inside of the car) to the temp sensor that controls the amount of heat the heater puts out. This hose might get crimped and cause the lack of heat. Where is this located???
Any suggestions would be appreciated.
I'm freezing my a$$ off when I drive my car. I'm in Toronto, Canada and it's about 2 degrees here!!!
Help!
I have a 92 SC400.
Help!
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I had my car done in less than 30 minutes, a year or so ago. I truly forgot what the procedure is/was.
I will try to get that info for you ASAP...
