SC- 1st Gen (1992-2000)
SC400 = killer
Old 02-11-07, 03:48 PM
XxSC400xX
XxSC400xX's Avatar
Wow! Looks like a new cold air intake! j/k
Good luck on getting it fixed, hopefully better than before.
Old 02-11-07, 03:52 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
reach under there and pop that sucker back out. The only metal part you should encounter that would hinder restoring it's shape will be the part holding the hood rubber seal to the top in front of the radiator and it's pretty flimsy so not a big deal.
pull rubber seal off, remove bolts underneath.
Old 02-11-07, 04:01 PM
Blizzy
Blizzy's Avatar
are you suggesting that the bumper is repairable? Or, is this a temporary fix suggestion to make the car look better in the meantime until I get a new bumper?
My engine loves me. My bumper hates me.
Old 02-11-07, 04:20 PM
XxSC400xX
XxSC400xX's Avatar
I was thinking the same thing. I would leave it as it is until after dealing with the insurance company. It looks worse than it is.
Old 02-11-07, 04:59 PM
MJHSC400
MJHSC400's Avatar
It is repairable-- it just depends on what actual material it is as to how it needs to be repaired.. I think it's a stiff urethane-- which can be burned back together, and that works much better than glue--
Once you've burned/melted it back together, you can put a few layers of fiberglass behind it for strength-- sand it right and noone will ever know.
Old 02-11-07, 05:05 PM
FortuneLS
FortuneLS's Avatar
SC's are good for killing animals...
like the stupid raccoon i hit recently
this is the damage from the raccoon i hit in my current 97 SC300
Guardrails are good for killing SC's...
like the steel one i hit a few years ago
this is the fatal damage from the guardrail i hit in my 93 SC400 3 years ago
Old 02-11-07, 07:01 PM
vince1128
vince1128's Avatar
enjoyed the story, and the sc is beast
Old 02-12-07, 03:00 AM
Blizzy
Blizzy's Avatar
Originally Posted by menappi
HAHA funny comment about it being a killer. I'd say you're prettty lucky though, it could of turned out like this... http://www.pbnation.com/showthread.p...1&pagenumber=1 (beware lots of gore, I'm sure most of you have seen it though)
Jesus. I was more than lucky in comparison.
Old 02-12-07, 08:18 AM
mkorsu
Zombie Slayer
mkorsu's Avatar
Glad you're ok Blizzy!
The SC came out like a champ!!!!
Old 02-12-07, 08:37 AM
CyBorG
CyBorG's Avatar
Originally Posted by Blizzy
SC - 1
Bambi - 0
hahahahhahahahaha
Old 02-12-07, 11:09 AM
lfrers
lfrers's Avatar
welcome to the deer killer club
Old 02-12-07, 11:23 AM
narfy
narfy's Avatar
wow.. the pics of the first deer hit look like it just needs an upper reinforcement and some bumper cover repairs and some paint... lucky you...
Old 02-12-07, 05:14 PM
lighthalo
lighthalo's Avatar
wow, for some reason im laughing.. i think because of the response it received...
Old 02-12-07, 05:17 PM
Dr.Zeus
Dr.Zeus's Avatar
Yea the front bumper took a bit of a beating but the rest of the car looks fine
Old 02-12-07, 09:07 PM
MJHSC400
MJHSC400's Avatar
I've got a bumper for a g20 that had a badly cracked lower valance-- the bottom half was nearly cracked in half--
I burned a groove along the crack, then trimmed excess material from the back of the bumper in an unnoticeable spot, and proceeded to melt those pieces cut into strips into the groove-- like welding-- and melting-- sort of--
After getting the pieces to hold, I put a thin piece of cardboard behind the crack, and used a 2 part epoxy that is relentlessly strong, and may layer some silicone over that for weatherproofing, but you get the idea.
Had it been for an sc, I would've gone more high tech with the reinforcement material, like fiberglass-- The resin is sticky as he double hockey sticks and a few layers will make it strong enough to hold it's shape indefinitely, unless you ram something of course.
A little heat from a heat gun can help shape the material if you need to smooth a crease from a buckle-- and it can also be sanded with progressively finer grits until it's undetectable when shot with primer.
My G20 bumper came out near perfect.
I sprayed it with a single stage in cans, and then wetsanded it to a mirror shine-- looks oem-- (BTW-- this bumper used to be black vinyl/blue paint) I did this paint job on my front porch with rattle cans!
718murdoc
51
03-08-10 11:36 AM
KORUPT8D
Northeast
07-17-08 02:59 PM
kristalys
61
10-09-03 05:45 AM
Shanker300
14
04-30-02 09:07 PM
Quick Reply: SC400 = killer
