sorry for the newbie question
Im new to the whole car scene. I cant seem to disconnect the fog light bulb from the car. What exactly am i suppose to be disconnecting. The bulb itself or the bulb with the wire? It doesent help that I can barely see anything, i would have to remove the whole splash guard to actually see something. Sorry for the newbie question but I cant seem to find the answer. thank you.
Yea the headlights are 9006(low beam) and 9005(high beam) so both of those you first unclip the harness from the bult, then turn the bulb and you should be able to pull it out. The foglights on the 95+ are H3. Those I think you first have to do the same as if you were to remove headlight bulbs. You should then be able to see the back of the bulb with 2 wires that connect to the housing you just removed. There is a metal wire clip that is holding down the bulb so just undo that to free up the bulb. After, just disconnect the two wires from the bulb and do the reverse when installing the new bulbs. It might be a bit different on the SC so just use common sense.
If you are replacing with Halogen or Xenon type of bulb DO NOT TOUCH THE GLASS with your hands it shortens the life of the bulb, use a napkin to prevent touching the glass when inserting the new bulb.
