SC- 1st Gen (1992-2000)
How do I move dead seats in a 95 SC300?
Old 03-10-07, 12:07 PM
carliejoe
carliejoe's Avatar
Default How do I move dead seats in a 95 SC300?
Greetings all.
I've a 1995 SC300, with either a dead Seat ECU or two dead seats. I'm thinking it's the seats, the wife left the sunroof open in a rain storm and there was a serious amount of water in the floor. After drying everything out, the seats worked for a couple of days and then gradually all the motors quit responding.
I've decided to swap the seats for a set of Tan leather Supra seats, more sportier , but I've run into a problem.
One seat is all the way back, so I can only get to the front bolts. The other is far enough forward to make getting to the front bolts impossible.
Isn't there an "emergency" release to allow the seats to fold forward and then slide out of the way for rear passengers?
I can't get even a thin boxed wrench on the hidden bolts to get these things out, and I really don't want to torch the seats loose.
I'm not opposed to cutting the leather off, and removing the foam in the seat bottom, if it'll help. It looks like there should be some kind of slide release, but either my tracks are rusted solid, or the seats simply don't do that.
Any help is appreciated.
Old 03-11-07, 06:33 AM
carliejoe
carliejoe's Avatar
Never mind, I'm clearly the only one this has ever happened to.
Old 03-11-07, 08:30 AM
sc250tt
sc250tt's Avatar
if you can get to the front bolts thake those out and rock the seat back to forth until you brake the brackets out .then you gcan get your rachet and screw out the the peices that are on there .good luck
Old 03-11-07, 10:13 AM
hemogoblin
hemogoblin's Avatar
Same thing happened to me during a motorswap. Aliga told me this. On the rail closest to the shifter, there is a 10mm bolt, just turn the thing, and the seat will move forward or back.
Its inside the rail itself, so when you look at it, your also looking toward the rear of the car. Hope that made sense.
Old 03-11-07, 10:31 AM
booja
booja's Avatar
^^^^ i gotta try that. my pass seat doesnt move at all and its stuck all the way foward
Old 03-11-07, 06:16 PM
sc250tt
sc250tt's Avatar
yup exactly what i found out today worked good for me
Old 03-12-07, 08:46 AM
aliga
Former Sponsor
aliga's Avatar
works all the time
Old 03-13-07, 11:43 AM
XxSC400xX
XxSC400xX's Avatar
Ali is the man. I would have never known there was such a simple solution.
Old 03-13-07, 01:53 PM
bezee
bezee's Avatar
Default Moving seat all the way back
Question.....After turning this bolt will i then be able to push my seat all the way back and then tighten it and it will stay secure? Thanks guys cuz the motor on my passenger side is dead and most of my passengers are pretty tall.
Old 07-28-10, 06:52 PM
Dx3
Dx3's Avatar
OK, anyone have a pic of the location of this 10mm bolt because I'm not seeing it
Thanks,
Jonny
Old 07-28-10, 07:10 PM
Dx3
Dx3's Avatar
Sorry it's upside down
Jonny
Old 07-28-10, 08:41 PM
ImpactBlue
ImpactBlue's Avatar
Now it's right-side up. Can someone MS Paint circle/arrow the 10mm bolt location for us? And this is the driver's seat, yeah?
Please and thank you!
Old 07-29-10, 07:46 PM
FaLKoN300
FaLKoN300's Avatar
I think it's that gold one on the bottom of the rail there.
Old 07-29-10, 09:34 PM
dwebb99
dwebb99's Avatar
People the 10mm nuts are located (slightly recessed) at the FRONT of the front seats right above the sliding rail on each side. Two to a seat. You have to get your head down right in front of the seats to see them. A flash light would be a good idea. Use a socket with a short extension. By turning the nut(s) you are just manually turning the motor gear to move the seat. It's a Lexus, these guys think of EVERYTHING.
Old 07-30-10, 05:41 AM
Dx3
Dx3's Avatar
So do you have to remove the front trim piece on the seat?
Jonny
Quick Reply: How do I move dead seats in a 95 SC300?
