steering adjustment (electrical) problem
is it a pretty common problem how the SC300/400 electric steering wheel adjustment goes bad?
how easy/hard is the fix? what parts would you need to get it done? it still retracts and goes out fine but doesn't go up and down.
just randomly went out yesterday... now it's annoying just sitting right on my knees
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Take the cover off the steering column, take off the metal cover on left side, slide the gear out, stick any washer you got laying around behind it to space it out a tad, and do a quick test to verify it works good again, and put back together.
Hi!
check this thread:
https://www.clublexus.com/forums/sho...t+wheel+repair
You're "lucky" because usually its much easier to access/repair the up/down motor than the in/out.
Mine doesnt moving in/out, and I was unable to locate the motor which moves it. Search did not help for me![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Good luck![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Attila
check this thread:
Good luck
Attila
SC250tt- i think you're wrong. i've found some pretty useful information from the two guys who wrote useful posts. thanks for the tip though ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
MANI and ATTIS - you guys are awesome, much appreciation for the help! i'll give that a try to see if it fixes it
dumb *** me, was able to get the clam shell off and got a "rubber" washer from the gardening isle, it was for a hose
put just one on and put it back together and it's working like a champ again!
thanks again for all the help and for the one who discovered the FIX!!!
