Lighting ISSUE!
Lighting ISSUE!
I was tinkering with the side marker the other day to replace the bulb when suddenly it clicked off on me. I was replacing the bulb, turned it on, then it stayed on after like 5 mins they turned off. Now, my markers dont light up neither will my side lights(The smaller bulb in the headlight, not the turn signal). I need help, I'll probably take it down to toyota later in the month but if this is a possible DIY repair, then I'd like to do it myself. Any suggestions?
-Chris
-Chris
look inside under the driver side there is a fuse box there little black box once you take it out behind it, it should tell you which fuse it is. if not theres a fuse box in the engine area.
I have replaced the TAIL fuse and still nothing, should I replace the bulbs too? It's ironic that both the tail running lights AND the smaller low beam headlights stopped working on the same day, at the same time though.
