any fender mod
would I be able to get away with jsut cutting off the inner mecause i dont wanna go painting my car so many times..i have planned to shave my antenna too..so id wanna get the whol car painted at once.....or jsut make it easy on myslef and get the 3.5 inch lip..instead of the 4.75 inch lip
i think your looking at the same rims i am. the widetracks? i was told many times that the rear would fit fine with cut or rollled fenders, it wont stick out, but it will be aggressivly flush.
ps. a heat gun in conjunction with the fender roller is the perfect combination to ensure paint is undamaged.
You'll definitely need the guards at least rolled if not shaved. Be careful with your tyre selection as well. I'm hoping I can get away with 19x9.5" on a +29mm offset (265/30 tyres... not looking for a big stretch) up back with just a roll.
Dont cut your fenders unless u know how to weld......its not a good idea...just a good way to ruin a car if not done correctly.
rent or buy a fender roller. Its the easiest way but by no means is it fool proof. check the other threads here on rolling vs cutting.
Id suggest other methods but youd prolly mess up your quarter panels if you have questions at this stage.
