I need your advice
I need your advice
I live in pa doing auto body,About a year ago i purchased a 1992 sc400 that was in an accident, but not a bad one, I installed the left rear suspension,the left frond fender was damaged i repaired that but being that it took me sooooooo long to get to it i had to buy 4 brand new tires i also baught rotors all the way around and break pads, i had to replace the left rear abs sensor send one rim out to get refinished and well now this is the problem im stuck financially and i still have to get
1-battery
2-allignment(4wheel) my shop doesnt do them
3-flush all fluids and replace
4-inspection
5-mount and balance tires(same time as allignment)
6-replace serpentine belt
7-some paint work and minor door dings...................................................................................................................................the motor sounds amazing and has 99,000 miles on it i baught the car for 2-2500 and so far i put about between 2-2300 in it which brings me to around between 4-4800 with prob about 1000 or less until the finish line.And then today i got an offer from a guy i work with for 3300 and the only reason im thinking about it is because i can really use the money i know its a big loss but what do you think
ne way in this condition right now what do you think is a fair price
1-battery
4-inspection
not bad but before you spend another dollar you should devote a weekend to this site and learn more to spend less you could have saved plenty on those parts...believe it or not a few members on here are very friendly and can give good advise what part of PA are you in?
sell it to him AS-IS and run. I've seen 92's in better shape than that for less than $5k... clean title... and not so much wrong mechanically either.
if you need parts, PM OG member "aliga" and he can get parts to you cheap. If you fix all of those mentioned in your original post, ask for more $$$. If not, take the offer, and let him do the rest.
tangcoral
15
06-05-08 01:56 AM
