Beep Beep after fuse check
I did a search but was able to find only one post with no resolution. Can someone please help me out on this...
Mine is a 96 SC400. The a/c stopped working so I had fuses checked by a neighbor as I'm not mechanically inclined at all. Figured out that it was the compressor which is what I'd thought anyway.
But now when I start the car, there's a very faint "beep beep", few seconds later it does it again. It's coming from the instrument panel and no indicator lights are lit. I read through the manual, searched this site, and googled it. Nothing. Any ideas?
Thanks,
Melissa
Thanks,
Melissa
you should double check your fuse again to see if everything correctly in place and push all the way in. Your a/c compressor might go bad. How many milages on your car? I hope this help https://www.clublexus.com/forums/sho...d.php?t=278000
