How To Install The Actuator Sc400
I just purchased the actuator for the driver door. I would like to know if anyone have instructions on installing it. Or know a good place to have it done at a reasonable rate near Atlanta, Ga.
I dont exactly have a set of instructions written up but what you want to do is:
-Make sure window is all the way up
-Remove the door panel
-unhook the door lock cables
-remove the three screws that are visible from the side of the door around the lock area
-remove the nut on the window rail
-and pull the thing out
Thats how I did it. I dont know if anyone else has an easier way to do it.
Former Sponsor - Cancelled
Make sure you get one of the little yellow replacment clips that goes on the end of the rod & into the door handle. I broke mine even though I knew i wouldn't be able to get a replacment quickly, and was being very gentel with it. You can get that part at toyota for about 6$ thank god.
