SC- 1st Gen (1992-2000)
my door wont open on the sc300
Old 05-20-07 | 12:08 AM
clean's Avatar
clean
Default my door wont open on the sc300
my right door wont open, how can i get it open without messin up anything
Old 05-20-07 | 12:20 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Why don't you review the other threads on the subject?
Old 05-20-07 | 12:23 AM
DY3VERSITY's Avatar
DY3VERSITY
Use the door handle.
Old 05-20-07 | 01:48 AM
clean's Avatar
clean
could you give me the threads i cant find them, and i tries usind the handle, and i tried using the key and pulling the handle
Old 05-20-07 | 01:58 AM
clean's Avatar
clean
o yea my door wont open from the inside or outside
Old 05-20-07 | 06:42 AM
aliga's Avatar
aliga
Former Sponsor
you have the break the door panel
Old 05-20-07 | 07:38 AM
tritron's Avatar
tritron
i would not try to break anything. You should see screws that you can remove there is one behind plastic cover on inside handle and two above the pocket. remove the screws and see if you can get some room to work.
Old 05-20-07 | 08:22 AM
aliga's Avatar
aliga
Former Sponsor
lol, have you tried this before. you will have to break it.
Old 05-20-07 | 09:13 AM
Djdot2k's Avatar
Djdot2k
from the interior, try holding the lock in the open position manually then do the same with the door handle. if that don't work. yeah you will have to tear thought your door panel.
Old 05-20-07 | 10:54 PM
clean's Avatar
clean
yea thanx guys i tried the screws and it deff wasnt no room to work at all, so i got a air saw and cut it down the middle
Old 05-21-07 | 02:11 AM
aznxenon's Avatar
aznxenon
ouch. i'd hate to take an air saw and cut my door panel down the middle.
Old 05-21-07 | 10:05 AM
SCoupe's Avatar
SCoupe
CL Folding 25,000
What did you find once you opened it up?
Old 05-21-07 | 01:09 PM
PsiQo1's Avatar
PsiQo1
damn .. that sux..hope this never happens to me ... what was the problem?
Old 05-22-07 | 02:08 AM
clean's Avatar
clean
i brought the car from a guy last week and he said he replaced the door latch but when i cut my passenger door panle with the air saw i found out that the latch was stuck due to there was no grease on it, nothin to lubricate it so that it can pop back open, but i sray some lube on the latch and it opened
Old 05-22-07 | 02:55 AM
Fireblaze's Avatar
Fireblaze
Good job on the fix. I was going to suggest jumping in through the window with style but I guess that wouldn't work too well.
