striped nut
striped nut
I was trying replace my struts in trunk I manage to replace one side by the right side it just striped the nut so i cut off the strut using hacksaw. how I remove the nut now so i can install new strut.
Yes i am there is nut behind the bracket that i belive can't be removed. i gues i need to drill out the old screw as i broked part of it and the rest is stilll inside the second nut
First of all you can get a socket that removes stripped nuts. I believe you can get some at sears, but not sure if they have it in the size. Before you use the new socket, you have to heat up that area with a lighter because there is some chemical from the factory to prevent it from becoming loose. I almost stripped mine as well, but read the thread by howiedoit and the lighter did the trick.
Ariyanna
12-11-09 01:41 PM
