6-speed swap info needed
Is the Supra TT 6-speed a direct bolt-in for a '94 SC300? If not, what modifications need to be made (just for mounting)? I read that on some, you have to cut the tunnel and make a plate. Could anyone give some specifics?
send a PM to Jeff, SC300TURBO
If the car is a manual its easier... you only need the 6-speed transmission mount, clutch, flywheel, custom driveshaft, and the 6-speed slave cylinder...
if its an automatic, you also will need the 6-speed clutch master cylinder, slave cylinder, and all the stuff that goes with the clutch pedal box (supposed to be a PITA to install)
I think the 94s may not require hammering... only the early model SCs, I could be wrong, Jeff will know about this since he's done it...
