Wiring Diagram for headlight switch
does anyone have the Wiring Diagram for headlight switch.. i want to splice the sidelamp lights on the bumper to stay on when i turn on the headlights...
Maintenance Moderator
I suggest using an alternate power source and a relay...
adding 35-55 watt fogs on top of the stock 55-65 watt headlights might be too much to ask of the factory wiring... Although I don't know the exact wattage rating of the stock wiring...
it'd be simple though, one relay, wire to both fogs, constant positive from the battery, a ground to the chassis, and a source to switch the relay from the factory headlight... a simple voltmeter or test light will tell you which is positive real quick...
SexyLex
IS - 1st Gen (2001-2005)
06-27-02 11:16 AM
