heavy SC
heavy SC
Is it correct that the SC300 weighs almost 200 lbs more than the IS300? why is that? both have leather, both RWD. maybe its the huge SC hood, lol.
IS300: 3,328
SC300: 3,506
i found slightly different numbers from different sights (all have SC weighing more), but i figured i'd trust Wikepedia's numbers, lol.
IS300: 3,328
SC300: 3,506
I think 2500 may be low. 3650 sounds more right to me. The IS is newer and smaller. The SC is real long. The doors are so heavy they can bend the factory hinges over time.
Fortunately, this all makes our cars very safe. Whether nailing a guard rail at 85 or killing Bambi at 55, our cars seem to walk away from wrecks like a champion.
Thats right. Our SCs weight about 3650. Our cars are bigger than the IS and the SC can handle an accident like a tank. These are pretty solid built cars that were made to last. Have you seen pics of the SC in an accident? Pretty much everything gets crunched and the cabin will pretty much keep its shape. Very safe car. Very heavy but very safe.
Don't forget the 1st gen IS has a slightly more compact 2jzge than the SC 2jzge. SC also has dual exhausts.
According to autos.msn.com, a 1996 SC300 weighs 3,560lbs and the SC400 weighs 3,610lbs. The weights fluctuate by a few lbs for different years especially the 1998+ models. You can also look up weights of other cars there as well under the "Features" tab then under "Exterior".
No Sir, I Don't Like It
Build an SC300/400 today out of parts they would use today and take an older one, now put both of them in the exact same accident, oldschool will win. Thats the problem with new cars today, too cheaply built, materials wise. Its all about weight reduction today and fuel efficiency. I bet that little savings in you're pocket won't be doing you any good once you're in the ground.
Personally i don't mind the heavy set car at all, doesn't feel too much heavier than my old maxima and handles just fine.
