Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#2117
#2121
What would you guys go with for spacer?
Will be running 18x8.5 35offset with 245/40/18 in front
rears are 18x9.5 45offset with 275/35/18 in rear
not sure if I should go with a 10m or 15mm spacer in the rear
kind of leaning towards the 15mm but dont want to pull fender
at all....plan on cutting the lip though
#2124
Dude... 25 mm in the rear for sure! At least! 45 offset is so high.
I'll mount up my 18x10.5 +16 and show you how it sits on cut fenders. Perfection. You can definitely go more aggressive.
#2125
He has 275's... without running major negative camber, +30 is about as low as he can go with rolled/cut fenders...
I run +35 and 285's with -2.5 camber and completely flat rolled fenders and there is less than 5mm of space, my pinky won't fit between the fender and the tire...
#2129
