SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 03-12-09, 12:59 PM
  #2191
justinSC
justinSC's Avatar
For reference purposes:
2 rear wheels mounted. Specs: 18x10.5 +16 offset 245/40. Lowered on Megans. Definitely still needs work. If i can find 2 more wheels I'll lower the car more and add camber in the rear, along with going with a 35 series tire, and possibly roll the fender out a little.
Old 03-12-09, 04:01 PM
  #2192
Jfg kevin
Jfg kevin's Avatar
hey Justin...Did you get rid of your sterns in replacement of those rims?
Old 03-13-09, 12:15 AM
  #2193
FormosaSC
FormosaSC's Avatar
f:19 x 9.5 et+12
r:19 x 11 et+17
What would i need to do to fit this?
Old 03-13-09, 12:20 AM
  #2194
surrealSC
surrealSC's Avatar
Originally Posted by 1SickSC
f:19 x 9.5 et+12
r:19 x 11 et+17
I too would like to know this as well but im looking at a 19x9.5 and 19x11 with +20 offset? willing to roll the fender but not pull. what size tires?
Old 03-13-09, 01:03 AM
  #2195
marcuse
marcuse's Avatar
Ok....
I want a wider stance with what I've got if at all possible.
Tires 245/45/17
Wheels :17x7 +38 offset SSR Integral A2's
Suspension: Tein Flex Dampers
How should I go about doin it?
I want the rims to stick out of the fender a tad... Wheel spacers? Which kind? Stock studs?
Old 03-13-09, 01:13 AM
  #2196
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
im using F245 and R275
with that combination you will most likely have to flare the fenders after major rolling and pulling
Old 03-13-09, 01:16 AM
  #2197
marcuse
marcuse's Avatar
^answers anyone?
Old 03-13-09, 01:21 AM
  #2198
justinSC
justinSC's Avatar
marcuse: get the widest spacer you can... maybe 30mm lol
1sickSC: You can roll out your fenders and it will fit. Look at mine a few posts before yours.. your rears would only stick out slightly more and those ALMOST fit lol. But then again I'm running a 245 series tire, you might want to stretch it a little more, or just pull out the fender.
Old 03-13-09, 01:23 AM
  #2199
justinSC
justinSC's Avatar
Oh and kevin: No I still have the sterns. One of them has a small crack thats letting out air and instead of fixing it I bought the Garsons. Only thing is, one of the Garsons never arrived in the mail, so I've only got 3!
Old 03-13-09, 01:32 AM
  #2200
marcuse
marcuse's Avatar
Where do I find them at and also... any other supporting mods I need to do to use them safely?
Old 03-13-09, 01:48 AM
  #2201
justinSC
justinSC's Avatar
I've bought some off ebay that have worked pretty well actually. They come with all the studs and bolts so you just bolt em up. I've never had any problems using them, always seemed perfectly safe. You might not actually need 30mm. You should do measurements to see how much you'd want it to stick out.
Old 03-13-09, 01:59 AM
  #2202
marcuse
marcuse's Avatar
30 the maximum I can go? I found a 30 on ebay 100 bux for just two! Yikes..
Old 03-13-09, 06:52 AM
  #2203
JPSFAB
JPSFAB's Avatar
I need help!! I got 19 x 8.5 +43 and 19 x 10.5 +28. What size tires should I go with for the rears? I know for sure I need to roll the fenders. I'm thinking of going with 245/35/19 but it might be too stretched. But, it seems like 265/30/19 would be the proper tire size for me. What do you guys think?????
Old 03-13-09, 09:06 AM
  #2204
justinSC
justinSC's Avatar
Well when you're already going to be sticking out so much then it is... I guess it just depends on how much fender work you want to do. Yeah, you can make them fit.
Marcuse: 30mm will stick each wheel out over an inch. For the most part thats the largest spacer you'll see. 100 bucks for the pair sounds about right too, you might be able to find some for around 80.
Old 03-13-09, 10:38 AM
  #2205
surrealSC
surrealSC's Avatar
any info on this? any rubbing clock to clock? is there a need to pull?
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
