SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 10-23-09, 02:00 AM
  #2461
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
yeah why is that?
Old 10-23-09, 07:04 AM
  #2462
SH_JZZ30
SH_JZZ30's Avatar
Because all the stickies are in this thread....
https://www.clublexus.com/forums/sc-...ere-first.html
Old 10-23-09, 02:12 PM
  #2463
nnnickkk
nnnickkk's Avatar
how well would 18x9.5 and 18x10 +38 all around fit?
Old 10-23-09, 02:16 PM
  #2464
vinh
vinh's Avatar
it will fit pretty nicely. A little roll and you should be fine. What kind of look are you going for?
Old 10-23-09, 02:38 PM
  #2465
nnnickkk
nnnickkk's Avatar
Whats up Vinh! Im either goin to go with 18x9.5 and 10 +38 all around, or 18x9.5 +15 and 18x10.5 +15. I dont want stupidly stretched tires, so im thinking of going with the +38, beefy tires, then a 5 to 5mm spacer to get it to sit out a bit farther if need be.......... Car is on Tein Basics, so its gonna be low
Old 10-23-09, 05:51 PM
  #2466
vinh
vinh's Avatar
watsup playa!! That setup should be perfect since you wanna run a full profile on the tire. The 10.5 is probably going to need some stretch/camber/slight pull for sure. I'm going to go ahead and assume you picked up an sc again.
Old 10-23-09, 09:32 PM
  #2467
FuMoFFuTT
FuMoFFuTT's Avatar
I'm looking at some new wheels..
Work VS-XX
I'm getting the SUPRA TT calipers soon, so I guess I need the (R Disk) type wheel in the front and (O Disk) type in the rear? I want nice fitment, rolling and MINOR pulling if anything. If I don't need to pull, it'll be better
Will be slammed on Tanabe Sustec Pro-Five coilovers
Here's what the choices are
18x9.5 + 26 (O Disk)
18x9.5 + 14 (O Disk)
18x9.5 + 28 (R Disk)
18x9.5 +15 (R Disk)
18x10.5 + 26 (O Disk)
18x10.5 + 14 (O Disk)
18x10.5 + 28 (R Disk)
18x10.5 + 15 (R Disk)
Old 10-23-09, 10:11 PM
  #2468
Kaydee
Kaydee's Avatar
Originally Posted by ESScee400
I've posted this question a few times, so some of you may be reading it for the 2nd or 3rd time. I'm sorry, but I haven't really received a straight answer yet :/
This is my planned setup...
- Dropped 2" with TT shocks and lowering springs (already purchased and waiting for install).
- Wheels: Front: 19x8.5 +35 ; Rear: 19x9.5 +35
- Tires: Front: 235/35 ; Rear: 265/40 or 265/30
First, how will this look? Second, what fender mods will be necessary with the 2" drop? I'm assuming I will at least need to cut or roll my rears. Third, if someone has specs similar to this, please post pics! I'm anxious to see my future stance.
you will only need a mild roll with that for the rears, but the front will be sunken by alot...the rears won't look that bad, but with a 2 inch drop it will be sunken too. I'm not dropped that much and mine looks sunken, although still acceptable...check my sig (18x10 +38)
Old 10-24-09, 08:23 AM
  #2469
LetsSeeSC
LetsSeeSC's Avatar
im looking into buying Work Meister's just want to know if:
18x9.5 +16
18x10.5 +3
will clear big brake kits?
Old 10-24-09, 10:28 AM
  #2470
nnnickkk
nnnickkk's Avatar
buddy of mine did.......
so you think the +38's or the +15's? also someone told me the front +38 wont clear the front brakes? idk about that.
Old 10-24-09, 12:34 PM
  #2471
Myblacksc
Myblacksc's Avatar
Originally Posted by FuMoFFuTT
there's no way i can fit 18x10 +4 and 18x12 +3 ey?.. lol
225/35/18 up front
245/35/18 in the rear
20mm wide fender in the front with slight camber.
Flare and maybe -6 degree of camber in the rear.
But they certainly WILL fit.
What kind of wheels are they btw? pics?
Old 10-24-09, 12:44 PM
  #2472
FuMoFFuTT
FuMoFFuTT's Avatar
Originally Posted by Myblacksc
225/35/18 up front
Work Equips.. i won't be going this way though.. not convenient for track..
Old 10-24-09, 12:52 PM
  #2473
Myblacksc
Myblacksc's Avatar
Work VS-XX
18x9.5 +15 (R Disk)
I would run the 18x9.5 +15 (R Disk) up front with 225/40 and a roll. The 18x10.5 +14 (O Disk) in the rear with 235/40 with a roll/slight flare and some camber.
Old 10-24-09, 12:54 PM
  #2474
Myblacksc
Myblacksc's Avatar
Drift set up? I can recc. some wheel size.
Old 10-24-09, 03:27 PM
  #2475
SH_JZZ30
SH_JZZ30's Avatar
I'm now running 18x9.5 +9 (was +24 but I just installed 15mm spacers) R-disk up front with 225/40/18. And 18x10.5 +24 O-disk rear with 245/40/18.
My front has a slight roll and no fender liner. Rear is shaved and slight rolled. I had 265/35 in the rear but since I'm running a smaller tire, I can run less camber. I haven't gotten an alignment but when I do I'll try to get around -2 degrees or at least -2.5.
I will get new pics of how it looks real soon.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
