Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#2551
looked through 10 pages of this thread for an answer and callled to enkei(im a trooper). I just wanted to know what tire and offset id have to run with a 17x8.5 with stock fenders and 25mm flared fenders. Id also like to run a 17x10 in the rear. I have tein CS coilovers and putting on supra TT front and rear breaks. Im ready to buy the wheels I just want to get the proper fitment to sit flush with the fender or maybe slightly tucked. Help a sc owner out
In the rear with a 17x10, I'd say like a +24 ish offset would sit flush. Here's a 17x10 +12 on my car last winter.
![](https://img.photobucket.com/albums/v17/guessd/FILE0011-1.jpg)
![Name: FILE0044.jpg
Size: 74.2 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437755d1501401447-official-wheel-and-tire-fitment-guide-for-sc300-sc400-file0044.jpg)
#2553
Originally Posted by CP_Ree;5097711Here's a 17x10 +12 on my car last winter.
[img
[img
https://img.photobucket.com/albums/v17/guessd/FILE0011-1.jpg[/img]
![](http://img.photobucket.com/albums/v17/guessd/FILE0044.jpg)
what tire size did you use on the 10"?
#2554
No spacers. The FN's just come in those offsets, that's why they're so popular for those dori dori 240 drifters heh.
Those were tiny 235/40/17's. They were off a 240 so I figured I'd use 'em til they wore out, but I sold them to some other 240 owner before I got thru with them.
#2555
This was the wheel setup I have had in mind for a while now...
Rear: 18x9.5 +15
Front: 18x8 +43 or +30
Regardless of tire sizes for now, how's the setup as far as being flush. Is the +30 offset in front too much? I don't want to have to pull fender, just roll or cut.
What tires for the rear? I had 245/40 in mind. I think what I'm looking for is a very mild stretch in the rear and in the front. What are the two tire sizes that I'm looking for so that the front does not look too square in comparison to the rear?
So first question: +43 or +30 in the front?
Second Question: What size tires for a mild stretch? I don't want to run negative camber.
EDIT: And I forgot to mention something. I would like to have the possibility of running LS big brakes up front, so I would like you guys to keep that in mind. The rims are MB Battles and I heard that they do clear big brakes, but I'm sure that the front offset has a lot to do with that. I hope that I don't have to pull my fenders up front to fit the brakes if I'm obligated to get the +30 offset. I don't think so...
Rear: 18x9.5 +15
#2558
Rear: 18x9.5 +15
Rear: 18x9.5 +15
#2559
the front is gonna be HELLAsunk(haha) with those offsets. If you can get a wider wheel, that would help, but otherwise, with that skinny of a wheel, you'll probably want like +15 offset and you might have to roll it. I'd suggest a wider wheel with less offset, like a 8.5 or 9 with a +20-30ish offset.
(This is a bad picture, but you can kinda see it)
This is a 8 in front +40 something offset.
![Name: IMG00081.jpg
Size: 66.3 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437753d1501401394-official-wheel-and-tire-fitment-guide-for-sc300-sc400-img00081.jpg)
This is a 18x9 +37 in front compared to stock fenders.
![Name: DSC00893.jpg
Size: 50.7 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437754d1501401394-official-wheel-and-tire-fitment-guide-for-sc300-sc400-dsc00893.jpg)
to give yourself an idea of a comparison to an 8" wheel, you can go here and input the widths and offsets.
http://www.1010tires.com/WheelOffsetCalculator.asp
Edit: I see they don't offer that wheel in those fitments. Maybe you can do a 18x8 +30 with a 15mm spacer... or maybe you can pull off a 18x9.5 +23 offset with a 225/40/18 in front.
I'm putting a 18x9.5 + 20 offset in front this week. I'll post pics if you want, or PM ya with them to see the fitment. I know it will require a little camber and fender roll though.
#2561
Ok I finally took upclose pics of my setup. They are crappy iphone pics though. I need to realign the car so the rear has a gap because of all the negative camber. My car is pretty much as low as you can go for a daily driver.
Specs:
Front: 18x9.5 +24 R-Disk with 15mm spacer making it +9 225/40/18 Nankang NS2
Semi rolled. No fender liner or black fender lip. Relocated harnesses. Smoothed out everything as much as I could so it doesn't cut the tire. I want to give the front a full roll.
Rear: 18x10.5 +24 O-Disk 245/40/18 Nankang NS2
Shaved quarterpanels. Slightly pulled with a baseball bat to clear the 265/35 tires I had before. Smoothed out everything so it doesn't cut the tire.
![Name: 1262061402.jpg
Size: 124.5 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437747d1501401394-official-wheel-and-tire-fitment-guide-for-sc300-sc400-1262061402.jpg)
![Name: 1262091131.jpg
Size: 86.6 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437748d1501401394-official-wheel-and-tire-fitment-guide-for-sc300-sc400-1262091131.jpg)
![Name: 1262091180.jpg
Size: 75.9 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437749d1501401394-official-wheel-and-tire-fitment-guide-for-sc300-sc400-1262091180.jpg)
![Name: 1262091198.jpg
Size: 88.7 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437750d1501401394-official-wheel-and-tire-fitment-guide-for-sc300-sc400-1262091198.jpg)
Specs:
![Name: 1262091208.jpg
Size: 95.4 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437751d1501401394-official-wheel-and-tire-fitment-guide-for-sc300-sc400-1262091208.jpg)
#2562
Just bought a set of 3 piece Work Rezax
Front: 18x9.5 +31
Rear: 18x10.5 +19
I might be using a 10 or 15mm spacer upfront to make it a bit more aggressive. Other than that a slight roll and pull should do the trick with a slight tire stretch. Maybe a 255/265 in the rear.
Also going to be as slammed as I can for daily driving on my megan coilovers. Just ordered the wheels from Japan yesterday so should take 2 weeks to get in. I'll update when they do get here.
![Name: work.jpg
Size: 122.9 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437726d1501401293-official-wheel-and-tire-fitment-guide-for-sc300-sc400-work.jpg)
Front: 18x9.5 +31
Rear: 18x10.5 +19
![Name: work.jpg
![Name: untitled-1.jpg
Size: 81.1 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437727d1501401293-official-wheel-and-tire-fitment-guide-for-sc300-sc400-untitled-1.jpg)
#2565
I have an opportunity to purchase some 17x8.5 wheels with a +24 offset. I was wondering if this would fit my sc300 with some 245 or maybe even 255's all around? The car is lowered about an inch. I don't mind rolling my fenders, but don't really wanna do any pulling.
