Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#2596
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
my old setup was 20x8.5 and 20x10. after spacers it was 20x8.5 +25 no rubbing issues. and out back came to 20x10 +27 i shaved the fenders to almost noting and then newspaper pulled and i had some negative camber also maybe -2.5. it shoeuld look good in the rear fron may need some spacers to be flush but it wont be sunken and would look good.
heres a pic
heres a pic
![Name: pic9.jpg
Size: 217.8 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/437529d1501400445-official-wheel-and-tire-fitment-guide-for-sc300-sc400-pic9.jpg)
#2600
Why do you want to run a 225/35/18? You will basically have no sidewall. Those wheel's aren't aggressive enough to require a tire that small. Run a 235/40/18 all around and just roll the fenders. Rolling the fender's isn't hard or that big of a deal. If you pay someone it's not expensive at all.
#2602
heres a pic
![](http://i612.photobucket.com/albums/tt205/SpiderN9NE/pic9.jpg)
heres a pic
#2603
I want to buy new RIMS that have 42 offset. Can I run 245/40/18 tires without any issues? Everything is stock.
Any help would be appreciated!
#2604
I'm stuck on tire size my wheels are 18x8.5 and 18x9.5 with a 35 mm offset all the way around, at first I was going to go with 225/40/18 in the fronts and 245/40/18 in the rear, but after thinking I would like to do 245/40/18 in the fronts and 275/40/18 in the rear. I plan on dropping the car after I put the wheels on and rolling the fenders if I have too, just need help on the tire size.
#2605
#2606
I am thinking to put an 18x8+40 front 18x9.5+40 rear "Petrol Throttle" on my SC4? I am quite sure it will fit without any fender rolling if I use 225/45 front & 245/40 rear.The only problem is I got a supra bbk, will that be a issue? helps are appreciated. Thanks
#2608
#2609
Going with a new set of wheels here shortly.
18x8.5 with a +30 with 245/40/18
18x9.5 with a +38 then a 7mm hub centric spacer with 275/35/18
Sitting on Buddy Club Race Spec coilovers and car will sit with roughly
3/4in of fender to tire gap.
If possible might run 11.5mm hub centric spacers in rear if it allows.
#2610
Will these wheels work on my 2000 sc300? Will it look good or will it be tucked to much? Any help is very much appreciated.
https://www.clublexus.com/forums/whe...omo-tires.html
Tony
Tony
