SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 10-20-10, 05:41 PM
  #2926
1uzfe4147
1uzfe4147's Avatar
Anyone have a 245/25/18 with 18x10 +6? OR seen something with the alike?
Old 10-20-10, 11:58 PM
  #2927
| evaN |
| evaN |'s Avatar
That won't fit unless you modify your guards. my virgin guards JUST cleared 17x9 +19 when dumped. and why 245/25/18? does that tire combo even exist?
Old 10-21-10, 10:13 AM
  #2928
1uzfe4147
1uzfe4147's Avatar
sorry that was a misstype 245/35/18
Old 10-24-10, 12:42 PM
  #2929
Schwieg
Schwieg's Avatar
is there anyone running ssr vienna kreis?
18's as well?
Thanks in advance for pictures and specs.
Old 10-24-10, 04:00 PM
  #2930
BayxSC
BayxSC's Avatar
i need help!!! just bought some rims....19x8.5 front 20mm offset/19x9.5 rear 35mm offset. What tire size shoul i go with im tryna put em on asap im anxious to get them on.
Old 10-24-10, 04:29 PM
  #2931
SChema
SChema's Avatar
^, 245/35/19 for the fronts and 265/30/19 or 275/30/19 for the rears.
May rub a little with the 20 offset in the front depending on how low the car is.
Old 10-26-10, 12:02 PM
  #2932
THETENXU
THETENXU's Avatar
I'm looking to get xxr 522 for the mean time and thinking of running 18x8.5 in the front and 18x9.5 in the rear what size tires and or spacers should I have. just ordered stance gr+. Just want a real aggressive look
Old 10-26-10, 05:11 PM
  #2933
SChema
SChema's Avatar
^, I suppose the 522's come in 35 offsets all around? If so you could probably get away with 8mm spacers in the front and 5mm in the rear on a stock bodied car.
Tires, you can run 235 or 245/40/18's in the front and 265 or 275/35/18's for the rear.
Old 10-27-10, 02:12 AM
  #2934
LXLUTHR
LXLUTHR's Avatar
99' SC400 *Help Please* Does anyone know of 5x114.3 to 5x120 15mm spacer/conversion adapters and what companies make them? And also how will fitment be with a 19x10 +5 offset for the rear? Will I need to pull my rear fenders or can I get away with just rolling my rear fenders and a little tire stretch?
Old 10-27-10, 04:57 AM
  #2935
laurante
laurante's Avatar
^ i just ordered some from www.lugmanusa.com
we'll see how that goes. what bmw wheels did you get? and 19x10 +5 will be fine, you have coilovers right?
Old 10-27-10, 07:39 AM
  #2936
TougeSC3
TougeSC3's Avatar
Will your offset be +5 with the spacer? If so you should be OK with a pull and stretch.
Old 10-27-10, 10:38 AM
  #2937
SChema
SChema's Avatar
^, what he said. Expect to add anywhere from 15 - 20mm more with the conversion spacers dropping the offset into the negatives. Even the +5 is too much for my tastes, I like to run a decent amount of tire, you'll have to stretch.
The ones listed by laurante are 1.25" thick, making it roughly 32mm thick, making your effective offset -27.
Old 10-27-10, 11:59 AM
  #2938
laurante
laurante's Avatar
lugman does custom stuff so i ordered 20mm for the front and i can't remember what for the rear. not sure if the front will clear the studs, i might have to cut some off.
Old 10-27-10, 12:59 PM
  #2939
lookEVO
lookEVO's Avatar
Im looking at 18x8 fronts and 18x10 rears... +35 offset on both going on my 1995 Sc300 on stock suspension for now as winter is coming... What would be a good size tire were I too decide to lower? I like a little stretched look but dont wanna have crazy expensive tires either.
Old 10-27-10, 02:25 PM
  #2940
SChema
SChema's Avatar
^, 235/40/18 for the fronts, 275/35/18 for the rears. I'm not into stretching tires. Those offsets are not really aggressive so you should not have to stretch the tires.
The fronts will be quite sunken though, you could use 10 - 15mm spacers for the fronts.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
