SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 11-15-10, 01:46 PM
  #2971
RawkusX187
RawkusX187's Avatar
Originally Posted by SH_JZZ30
Terry's wheels are actually 11.5" +37 in the rear.
Is it? I thought I've seen 11" +37 and I remember asking him also.
Old 11-15-10, 01:50 PM
  #2972
YeA 2jZ
YeA 2jZ's Avatar
Terrys fender work.....
Old 11-15-10, 01:55 PM
  #2973
RawkusX187
RawkusX187's Avatar
Yea you're right Shameed. I searched one of his post and saw his sig. So I wont have much of a proble. I know what im working with now.
Old 11-15-10, 02:01 PM
  #2974
RawkusX187
RawkusX187's Avatar
That looks like a regular pull that I know. Thanks yall!
Old 11-16-10, 02:26 PM
  #2975
WillyD
WillyD's Avatar
Originally Posted by C-unit
^ Go with +25, +35 will be sunken in Alot.
Here is mine:
18x10 +0 225/40R18
18x11 +0 255/35R18
Lots of fender roll and lower with Tein Super Drift.
damn man do i see two r32's in the background....doing it big!!! love the cars and i like the fender rolling
Old 11-23-10, 02:55 PM
  #2976
SChema
SChema's Avatar
Classics:
Front: 18 x 10, 285/30/18 BFG Gforce TA KDW's
Rear: 17 x 11.5, 315/35/17 MT ET street's
Will post offset and backspacing when wheels are off the car, since CCW doesn't give that information.
Old 11-23-10, 03:00 PM
  #2977
supralative
supralative's Avatar
Looking good mang!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-23-10, 03:01 PM
  #2978
SChema
SChema's Avatar
^, thanks man. Just need to focus on utilizing those rears now, lol.
Old 11-23-10, 03:54 PM
  #2979
Novoken
Novoken's Avatar
Hey guys im planing on getting some xxr 521 front 18x8.5 +30 rear 18x10 +25 Im runing KYB shocks and tanabe springs. I know I might need some spacer but would I need a roll? What tire size can I use without a roll?
Old 11-23-10, 04:22 PM
  #2980
SChema
SChema's Avatar
^, without a spacer you could use a roll or a mild cut on a 275/35.
Old 11-23-10, 04:29 PM
  #2981
Novoken
Novoken's Avatar
on rear? How about the front?
So no spacer on rear? How about the front?
Would it look better with spacer or it just wont need one?
Old 11-23-10, 04:35 PM
  #2982
SChema
SChema's Avatar
You can run a 245/40 on the front with no spacer easily with no fender mods; running spacers will depend on how aggressive you want to be.
Old 11-23-10, 04:41 PM
  #2983
Novoken
Novoken's Avatar
So its ok to run 40 in front then 35 in rear? wouldnt it look weird?
Old 11-23-10, 05:05 PM
  #2984
SChema
SChema's Avatar
On paper yes, the aspect ratio sounds odd. Once calculated, the sidewalls for the two aspect ratios will be nearly the same.
Front: 40% of 245 (tread width) equates to 3.85" x 2 = 7.7" + 18" (rim diameter) = 25.7" overall diameter.
Rear: 35% of 275 (tread width) equates to 3.78" x 2 = ~7.6" + 18" (rim diameter) = 25.6" overall diameter.
Both of these overall diameters are nearly identical to the OEM spec of 25.7".
You could run a smaller aspect ratio on the front to give you more of the raked look if that's what you're going for. So running the 35% up front would be no problem. The rears need to be as close to the OEM spec (25.7") to calculate the correct speed reading at the speedometer.
Old 11-23-10, 05:41 PM
  #2985
Novoken
Novoken's Avatar
got it.
Now if I go with 265 in the rear what would that put me in the front?
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
