Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#3092
CL Member Name: 93SCme
Rim Brand and Type: MRR GT-1's
Rim Size f/r: F:19x8.5 R:19x9.5
Rim Offset f/r: both +35
Tire Size f/r: F:245/35 R:275/35
Suspension Setup: Stock strut/Tanabe NF210
Comment On Ride: Need to go lower.
Fender Modifications: Rears are Rolled
Any other comments: Like the feel! but need to close the front gap.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Picture: Done with phone cam.
![Name: IMAG0012.jpg
Size: 111.4 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/435156d1501368207-official-wheel-and-tire-fitment-guide-for-sc300-sc400-imag0012.jpg)
![Name: IMAG0018.jpg
Size: 66.3 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/435157d1501368207-official-wheel-and-tire-fitment-guide-for-sc300-sc400-imag0018.jpg)
![Name: IMAG0016.jpg
Size: 61.2 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/435158d1501368207-official-wheel-and-tire-fitment-guide-for-sc300-sc400-imag0016.jpg)
#3094
I don't believe I am running neg. Last time i had an alignment was a month ago and that was with is300 rims with 225/50's on them so an extra 1.5 inch has been added with the 19's. Getting another alignment soon just to make sure.
The Tanabe's lowered about an inch in the rear, i could barely put my finger in between the tire and the finder, so I was rubbing like hell with the smallest of bumps . Bat rolled the rear fenders and no more rubbing.
Stock hight I bet you could get away with it, but I don't think so with the Tanabe's or lower.
![Name: IMAG0014.jpg
Size: 70.1 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/435120d1501368154-official-wheel-and-tire-fitment-guide-for-sc300-sc400-imag0014.jpg)
![Name: IMAG0015.jpg
Size: 46.2 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/435121d1501368154-official-wheel-and-tire-fitment-guide-for-sc300-sc400-imag0015.jpg)
#3096
Hi.
I'm kind of new to this forum..but I was wondering if someone could help me. I have a 92 SC300, and I was wondering if the rims from an 05 GS300 would fit my car..
The person i'm buying from thinks the bolt pattern is 5x115..but I'm pretty sure he's wrong because I researched and the 05 GS300 bolt pattern is 5x114.
These are 17 inch rims..supposedly.
Anyone?
Idk how to add pictures but hopefully this works:
Anyone?
#3099
the 18x10.5+22 will need a slight pull. I just took of my Works that were 18x9.5+19 and 18x10.5+19 with 235/40 and 255/40. All four corners were rolled and I had like a 5mm pull in the rear and only had credit card clearance in the rear. But there was no rubbing or anything
#3100
I don't think a roll will be enough. I ran 18 x 10.5 et 25 with 275/35's on aggressively cut fenders lowered to no finger gap, no rubbing whatsoever. I think if I ran a et 22, I would have ran into rubbing issues. All these numbers are on paper though, I had enough natural camber to clear the fenders. Only had the wheels for 2 - 3 months, never had the chance to get it aligned.
#3105
Yes but you may have to have extra camber or have to roll the Edge of the fender lip back a little Front and rear. Aslso your tire size plays a major factor. Id say you can go as wide as a 255 40 and probably not roll the fender in the back but up front you will want a 225-245 40 just for tractions sake you may have ot roll the fender regardless. Do you have coilovers?
