Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#3137
^, you may want to consider dropping down to a 35 series in the front and 30 series in the rear. Those you have listed are a bit tall compared to the factory diameter. Your speedometer will thank you for that.
#3138
265/30/19 R
Will this require a pull? I'm only interested in a roll since I'll have a 1-1.5 drop. Thanks schema
#3139
I think you'll be okay with just a roll with just a slight drop. 1 - 1.5" I'm picturing a ~finger gap?
The fronts will rub occasionally on hard turns and bumps. As for the rears, I think you'll be fine with a roll on the 25; 20 offset, not so sure.
#3140
I think I know the answer but wanted to double check with the experts to run 18x10 up front with a 255 series tire what offset should I run. Was thinking +3X??, I have a 5mm spacer on there from some previous wheels. I'm concerned about the inside being close to shock etc. Front fenders are rolled.
#3142
#3143
Yes sir, it does rub occasionally when going into turns aggressively and hard bumps.
These are the most recent.
https://www.clublexus.com/forums/sc-...-in-today.html
#3144
#3147
You need to consider the height of your car when calculating how flush a set of wheels will be. The lower the ride height, the more natural camber; therefore, the wheel will appear less flush.
I'd say if you have roughly a finger and a half gap from fender to tire (245/40's) you'll be pretty close. Nothing a thin spacer couldn't fix down the road.
#3148
The car will be sitting right on the tire, no fender gap. I guess if I needed a 10mm spacer finish the job right? because I doubt I can fit a 18x10.5 +25 in the front, which is what will be in the rear...
#3149
My 18x10.5+19 with a 235/40 fit in my front perfectly with no issues, only rolled fender and camber is only -1.4
