Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#3151
Hey everyone, what's up? This has probably been asked before, since this thread is HUGE, so my apologies if it has.
I really want to get a set of Black Axis Hiro's for my '92 SC400. The size I'm looking at is 19x9.5 +25 all around. Will these sit fairly flush; and, what size tires should I get? I was thinking 225/35-19 up Front and 245/35-19 in the Rear... but I was wondering if I could fit some bigger meats on there? I'm not even sure if those sizes would even be optimal, anyway.
Thanks in advance, everyone!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Edit: Forgot to add - I do plan on getting some coilovers, and lowering the car. Not sure how low I plan on going, though..
#3153
Would the linea corse lc818 fit nicely on 99sc400 lowered on springs? offsets are19x8.5 +30 front and 19x10 +38 rear. I have about an 1 inch gap between the fender and the tires. would i need to do any fender modifications.
debating between the lc818's or the mb battles 18x9.5+15.
#3155
whats up guys, does any one know where i could find a 18in wheel to fit a stoptech big brake setup? its on a 96sc400. factory stance. just want to make sure that before ordering wheels that they will clear the calipers. wanting a multi spoke wheel.
and i know this is a large thread and i tryed to use the "search" function but i jus wasnt coming up with anything. thanks guys for any help.
travis
travis
#3156
Rim Brand and Type:xxr 006 gold
Rim Size f/r:18x8.5 18x9.5
Rim Offset f/r:+35
Tire Size r:295/35/18
Suspension Setup:gab shocks/eibach springs
Comment On Ride:Really smooth not bumpy
Fender Modifications:Rolled
Any other comments:cant even put my pinky finger in gap... I doo have a camber adjustment
Picture:
![](http://www.use.com/d6ee1bb5d2a42b8dc5e9)
Rim Offset f/r:+35
Picture:
#3159
Rolling is no issue, I have 24/7 access to a roller, tire sizes are no issue either as I have a surplus of 20" tires that I can figure out what works best. No drop yet, possibly on H&R springs for now. Thanks!
EDIT: 245/30/20 & 285/25/20
Here are the sizes I was thinking.
#3160
Hope this doesn't seem lame, I've read the threads on this but just am trying to make sure of things. I have a '92 SC400, lowered with Tanabe springs and with stock size cross drilled rotors. Stock Tokino shocks. I have no plans to get bigger brakes. Currently I have 17 x 7 1/2 wheels with 225 50 17 fronts and 245 45 17 rears. I would like to go to 18s. Looking at Tirerack they recommend 245 40 18 front and 265 35 18 rear. I would be just fine with those sized tires. I was thinking about 8 or 8 1/2s for the front and 8 1/2 or 9s for the rears. So now the question, if I make sure of the bolt circle (5 114.3) and offsets will everything work. Do I have to worry about center bore, looks like there are 73mm and 60.1 mm available. In other words can I buy wheels by spec rather than having the seller specifically state the wheels work with my car. Thanks to one and all.
#3161
Try to get the polycarbonate ones if you can, aluminum last longer but have a chance of seizing up to the OEM hub ring.
#3162
im thinking about getting TSW zolders for my SC300. the offset is confusing. im guessing i need to go with +40 going from what i read on the first page.
18x9.5 +40 and 18x8 for the front. if i can get the same size for all 4 wheels and get 4 18x9.5 that would save me time. but 9.5 in the front is insane.
#3163
^, You'll be fine with 9.5 in the front if needed. I'm running a 10, 44 offset with 285's.
One of the more popular combos is 18 x 8.5, 245/40 in the front and 18 x 9.5, 265/35 or 275/35 in rear with +35 offsets all-around. Not super aggressive but a good place to start with untouched fenders.
#3164
Since I am running stock height for now I should be okay. So I'm gonna go with 18x9.5 for all four wheels. Unless its better to go with 8 inch wide in the front to avoid tire wear on the inside. Hmmm
#3165
I searched this and the general forum but, how would Scion xB wheels do?
o 18"X7.5"
o 114.3MM
o 39MM OFFSET
Seems like that offset is "better" than stock (a little more flush) and the width is a little wider than stock. Seems like an upgrade. I really am a novice so be gentle.
o 18"X7.5"
o 114.3MM
o 39MM OFFSET
