Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#3166
That's the same overall diameter I have run for a little while. I only had occasional rubs in the front in turns and rough roads. You should be okay with those. Personally, I'd be scared to roll around with such a small aspect ratio since roads here in OK are terrible. Biggest I'll ever go on this car are 18's.
#3167
I searched this and the general forum but, how would Scion xB wheels do?
o 18"X7.5"
o 114.3MM
o 39MM OFFSET
Seems like that offset is "better" than stock (a little more flush) and the width is a little wider than stock. Seems like an upgrade. I really am a novice so be gentle.
o 18"X7.5"
o 114.3MM
o 39MM OFFSET
#3168
The width of wheel is not going to dictate the wear of your tires. Your suspension geometry will, such as toe and camber. As long as your alignment is within spec, you'll be fine.
#3169
Ok cool, when I make my order I'll go with 18 x 8 and up front +40 and I will go 18 x 9.5 in the back +40.
Tsw zolders only seem to have 8 or 9.5 width for 18 inch wheels
#3170
#3172
#3174
18X9.5 5-114.3 20WM
18X9.5 5-114.3 40WM
this is what they have to chose from on Discount Tires Direct. so i need to get +20 for the 3 inch lip. and maybe a spacer. not +40?
and i just installed my 1jz last night. and the motor must be lighter than a 2jz. cause the front end is like 2 inches higher lol i need some springs big time!
#3175
^, Offsets are relative to tire sizes, in terms of fitment. Are you wanting to stretch the tires or run them normal? The ones I listed are for non-stretch. Stretching allows you to run more aggressively.
The front end hasn't settled yet. Once the car rolls a little bit, the front end should return to normal height.
#3176
#3177
#3178
19's or 20's
Hello all, I am considering upgrading my wheels. I am considering 19's or 20's in the katana wheels Kr12-19 or 20. I've check with 2 custom wheels company, but they are giving me to different tire size. Tire Rack is giving me 245/30-20, and another company is giving 245/35/r20 - 255/35/r20. Which ones will work without a lot of road noise and rubbing. As of now, I do not intend on dropping my car as of yet. But I do really need some help!!! I am ready to start some mods to my SC400.. Thanx guys!!!
