Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#3259
thinking about buying some tsw carthage for my sc300. 18x8 front and 19x9.5 for the rear. 20 offset on all 4. will i need to roll fenders or stretch tires? how flush will it be.
http://www.wheelwarehouse.com/p-5042...ge-silver.aspx
#3263
On the rear, the wheel will sit 6mm farther out than Mongols setup and 6mm closer to your suspension on the inside (not that it matters in this case).
#3266
Vince9164, this is an image of a 18 x 10.5 et 30 with a 275/35. I had added a 5mm spacer after this image was taken and clearance was still good, about another 5mm before touching the fender. Aggressively cut fenders to clear.
Hopes this gives you an idea what your fitment may be like. I think fitting a 265 will really depend on what tire manufacturer you buy from, as some run wide and some narrow and the amount of camber you get dialed in.
Good luck.
Good luck.
River2016 (01-29-22)
#3270
front 18x9.5+19 235/40 -1degree of camber and rear 18x10.5+19 255/40 with -3.5degrees of camber with fenders rolled flat and a slight pull
