Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#3286
Hey guy's I've gone thru a bunch of pages and haven't seen anyone running a +35mm offset.
The wheels I'm looking at are as follows:
18X8.5 about 2" Lip. 26.0 lbs ea
18X9.5 about 3" Lip. 25.5 lbs ea
Bolt Pattern: 5X4.5 or 5X114.3 (4.5")
Offset: +35mm
I plan on running 245/40/18 and 265/35/18
Will this require modification of the wheel wells?
EDIT: Forgot to ask- would I run into issues if I wanted to run the Supra BBK later on?
Offset: +35mm
#3287
^, You'll be okay, +35 is about the norm for factory fenders on those wheel widths.
You can go up to a 275 in the rear if you wish.
As far as clearing TT Brakes, it's hard to say. Offsets do not tell if your wheels will clear the calipers or not, spoke design does.
#3288
#3289
^, Definitely going to need to roll and pull the fenders if you want a decent amount of tire touching the ground. By decent amount, I mean at least 265's in the front and 285's in the rear.
#3292
Dont get anything less then an 18 inch. you will regret it. And make sure you Stay with a Smaller Number then +35, +25 is great, +15 Start Fender pulling
#3296
alright, i've read most of the thread, i know Sheema's setup is similar on pg. 218, but i just need this answered. I have a 95' sc, i'm looking at doing xxr 526. just worried about the rear 18x10.5 +20. i know i would have to roll the fenders, but could i do a good tire stretch and not have to do a pull or adjust camber?
#3298
#3299
UGGGH! I was guna throw the 17x10.5s from my s13 on my sc but now that i see how they fit with stock suspension ill probably not do it cus it looks like POOOOOP! even with waaaaay smaller tires its still guna be mexiflush at stock height
#3300
