Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#3406
sorry if this is a repost but i was thinking about these replica mustang cobra wheels and what would be the best fitment for the rear +20 or +27 17x10.5 and would the fronts working being 17x9 +24?
http://www.wheelreplicas.com/03deepdishwheels.html
#3408
well 265/40's are going to be a slight stretch on the rears, and you could run either the 20 or 27 offset, just with the +20 you might have to pull the fenders just a little bit. and if you want to keep the tires looking about the same you should go with a 235/45 up front, it should be about the same stretch. But also take a look at akapaco's really old SC, he had 17x9 et24 up front and ran a 245/40 up front and there was no stretch:
http://www.rimtuck.com/photos.php?ph...jpg&id=568&h=2
http://www.rimtuck.com/thumbnails.ph...&diameterf=17&
But regardless of all of this info, I and many others think 17s are small on SCs so keep that in mind.
Use http://www.rimtuck.com/ to your advantage, it really helps
#3410
I wish I could go 18s but at the moment that's out of my budget. It's pretty hard to stay in the 800ish range when your looking to get 9s and 10s with s good offset. I was thinking of just running the 19" g35s or the stock is250 wheels but I think it will be tuckin too much. Thank you for the heads up of the 17s looking too small on SC's I'll buy some bigger rims down the road.
#3411
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
sorry mods if im not suppose to promote for someone... i dnt know anyone from xxr just trying to help a fellow CL brother out
#3412
Here is a question if i use a "18x10.5 -7 fronts 18x12 -13 rear" how would this fit? im trying to grasp the idea of the lowest offset i can use but its not making too much sense to me. or if i go with Rear- 18x10.5 +3 Front-18x9+4
any help would be greatly appreciated!!!
#3415
How much fender work would i need to make these work? other than just the normal roll and pull? or would i have to use fender flares?
Thanks looks like i might go with the +4 and +3. depending on how much work needs to be done to make these wheels work.
P.S. you guys are the best . . . THANKS FOR ALL THE INPUT!!! ill be starting a build thread soon !!! just got a 97 SC3 and also just picked up a aristo 2j auto. Will be sourcing 5 spd swap too!! i have a R154 tranny already from a soarer.
Typ2nuk (11-10-20)
#3420
http://i214.photobucket.com/albums/c...0/IMGP5398.jpg
this is the same offset but on 18's i want same over all look and stance
