SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 11-26-11, 11:25 AM
  #3736
76mmturbo
76mmturbo's Avatar
Running 18x9.5 +22 18x10.5 +30 thinking 255 35 front and 275 or 285 35 rear dropped on espillar asd. Will I be ok? Fender will be cut today also.
Old 11-26-11, 01:18 PM
  #3737
CalitriSC
CalitriSC's Avatar
Yea good tire sizes for those offsets.
Old 11-30-11, 02:33 PM
  #3738
VINCE9164
VINCE9164's Avatar
Originally Posted by DoomLight
CL Member Name: DoomLight
Rim Brand and Type: TSW Snetterton
Rim Size f/r: F: 19x8 R: 19x9.5
Rim Offset f/r: F:+20 R:+20
Tire Size f/r: F:235/35/19 R: 255/35/19
Suspension Setup: Current: Stock Struts with Supra Sprint Lowering Springs
Hows the ride on that setup? What tires are you running? How much camber f/r? Thanks
Old 12-01-11, 09:20 AM
  #3739
DoomLight
DoomLight's Avatar
i have pretty stiff springs on it. it rides pretty okay. these 125 dollar lowering spring will have to do,till i can afford some megan racing coilovers.
it did camber in. however i can't tell u the exact amount.
i get some rub in the front. but i didnt roll the fronts, just the rear fenders. the rubbing in the front isnt enough for me to warrent a fender roll up there.
Old 12-02-11, 11:07 AM
  #3740
BeeMiX
BeeMiX's Avatar
Guys i have a TE37's that have following specs:
19x8.5J +52 FRONT
19x12J +65 BACK 295/30/19
ET is pretty big so i can use spacers to fit them right. But my question is by any chances i can fit them without stretching out fenders? Ill roll them up but i don't want to stretch them.
Old 12-02-11, 11:13 AM
  #3741
plex
1UZFE/2JZGTE
plex's Avatar
19x8.5J +52 FRONT
ET is pretty big so i can use spacers to fit them right. But my question is is there any chances that i can fit them without stretching out fenders? Ill roll them up but i don't want to stretch them.
You will need a 10mm spacer out back and the wheel will probably still touch inside fender at back of wheel in front of shock (not outer fender where outside of wheel is). I had to bang mine in about an inch and I'm running 18x12+54. With 295's on a 12 you should get away with a good roll. The inside area of wheel is where you will have to pay attention to.
Old 12-02-11, 11:48 AM
  #3742
BeeMiX
BeeMiX's Avatar
I've seen pictures of your car lately and it looks great ! Is there anything that you would change? Like +50 instead of +54 or its just perfect for you ? You had any problems banging those wells ? Im not gonna damage lining or something ?
So now my biggest concern is if i can find 10mm spacers that would change 5x130 into 5x114.3, because those wheels are for Porsche.
Old 12-02-11, 02:05 PM
  #3743
imDementeD
imDementeD's Avatar
tried searching real fast but i need a quick response
19x9.5 +45 all around...
where will i be around? thanks!
Old 12-02-11, 02:06 PM
  #3744
CalitriSC
CalitriSC's Avatar
The smallest adapters I have seen are 15mm. Most are 20mm for changing the bolt pattern. Or you can have the wheels redrilled to 5x114.
Old 12-02-11, 02:56 PM
  #3745
soarer479
soarer479's Avatar
any one know if the new work emotion cr kiwami's in 18x9.5 +38 and 18x10.5 +23 will fit my 97 sc its currently on tanabe springs and tokico's but may go to coilovers soon. Fenders are not rolled and id like to avoid it if possible but not totally opposed , also what size tires do you think i could get away with ? this is a daily driver thanks for any input
Old 12-02-11, 07:09 PM
  #3746
imDementeD
imDementeD's Avatar
any info at all on the 19x9.5 + 45?
Old 12-04-11, 10:28 PM
  #3747
BeeMiX
BeeMiX's Avatar
I spoke to my guy that can machine adapters for me and he said that 15mm is the lowest he can do. So that would give me ET50. Any ideas how would it look like ?
Old 12-04-11, 11:18 PM
  #3748
CalitriSC
CalitriSC's Avatar
with the 12" width? you could still fit it easily, just not with super wide tires.
Old 12-04-11, 11:20 PM
  #3749
BeeMiX
BeeMiX's Avatar
Im about to stretch 295/30 on that 12" so i guess i would be fine. Thanks guys !
Old 12-05-11, 05:05 PM
  #3750
kapetajr
kapetajr's Avatar
I am thinking of picking up a pair of 295/30/18 Pilot sports, I have 18x10 +42 rears, with the lips rolled. Any ideas on if the tires will fit without a pull?
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
