Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#4021
Hey guys, need to pick your brain. I'm looking at these wheels for my sc400. He says they bolt right up, What issues for fitment and tires sizes will I need. Just basically a run down of what I will need to do to make these work on my particular car. Hoping Raine will chime in and help out Thanks in advance guys,
-Eric
-Eric
Width?
Offset?
#4022
Hey some help would be great here guys... I'm picking up some SSR Sp1 SBC finish, 18x9 +19 high disk and 18x10 +24 medium disk. My fenders are rolled and I am dropped somewhat low. RIght now i've got some Rota Grids 18x9.5 +24 all around with 225/40/18 and 235/40/18. I'm just wondering if the tires on the grids will work on the new rims if not what should i go for?
I'm assuming the 225/40/18 will work in the fronts since the sp1 will be .5 smaller than the grids. The rears since are 18x10 i'm trying to figure out if the 235 would work or would they be way to stretched.
I prefer the low profile stretched look verses the beefy rear end look.
#4023
Yes I'm an idiot. Link is in the original post also:
https://www.clublexus.com/forums/whe...-must-see.html
#4024
#4025
As for the rear, just picture your current setup with 1/4 more stretch per side... it might be rounder depending on tire brand and model, but I think it should be okay for what you're looking for.
Here's link to wheels bro, thx: https://www.clublexus.com/forums/whe...-must-see.html
For the rear though, you'll need to do a roll for sure and a lot of pulling... you might have to flare the fender edge (where the lip actually sticks out like it was an add-on) because a 19x10.5 +12 will need a lot of clearance... or stupid camber.
Stupid as in half the tire tread will be in the air LOL
FUNCTION > FASHION
#4027
-Eric
Here's the link to wheels an all: https://www.clublexus.com/forums/whe...-must-see.html
-Eric
I totally agree on function over looks....but sometimes function LOOKS junk, lol. Everyone has their own taste though. Im at 640whp and with the stretched tire setup I have, I gets no traction. When I need traction, I slap on my DR's.
#4028
Eventually you get to a point where no street tire in the world will put the power down.
When that happens, this fixes traction problems for a little while.
We've put down 1100+ on this exact same tire on the Baltic car. The image shows the wheel and tire combination for the Alpine car, looking to put down ~1250.
#4029
wow, that is very nice! have you tried those on your sc to check clearance and fitment? If I ever get close to the 1kwhp mark, my rim style will change for sure! Those bad boys are serious business!
#4030
Ive had a whole bunch of different rim and tire combinations on my sc. Currently Im running a 19x9.5 +0 and 19x10.5 +0 and I have clearance with being decently low. With the rim you have/or want, you will for sure have to roll the inside lip and do a slight pull, like raine said....depending on what size tire you are going to run. Obviously if you don't want to pull alot, then you are going to have to do a decent stretch....prolly a 245 or so in the rear. Ive ran a 275 on a 10.5 +22 and the pull was only slight.
Exactly - that 640whp makes standard stretched tires become fashion > function
#4031
haha you are right. Im glad there are people who have rim/tire knowledge and can pass it on to others. People like you make this scene a whole lot cheaper and easier. Lord knows how much money Ive spent on rims and tires just trying to figure out what can and what won't fit.
#4032
I'd rather help steer people towards considering a setup that looks good and is functional - not sacrificing performance, reliability, or safety... better than seeing someone rock 5-degrees of camber just to fit some used "JDM tyte yo" wheels with the wrong offsets for our cars, only to have to tell them that it sucks. LOL
The only thing I don't like is when someone posts up expecting everyone else to give them the "perfect fitment" so that they don't have to do the work themselves. There's a wealth of wheel fitment examples and information in this thread that anyone should be able to get a good idea of what works and what doesn't, as well as how much work is needed to make things fit. Some of it is kind of common sense - how can you expect to fit an 11" wheel on stock virgin fenders?? Which is why if someone posts up with a fitment that's close (meaning they did research) and need some small tidbit of advice, I'll try my best to help them out... I know how it is because when I started I did a lot of research and it came down to one small detail before deciding on what fitment I wanted.
But... post up with "I want hella flush gangster stretch for my slammed SC, what size/offset should I get? thans in advance" I'd rather not reply, because I'll suggest 13x8 lowriders with whitewalls. Gold spokes, of course.
#4033
Pictured are the less aggressive Weld Drag Package with Skinnies on actual slicks instead of DR's.
#4034
this may be a noob question, but here it goes.
i know that having tires bigger/smaller than the original effects your odomter reading
so if i went up to 17" rims, say supra rims, would i have to subract roughly 2.5mm from the I.D.? im not exactly sure how tires are measured.
