Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#4037
this may be a noob question, but here it goes.
i know that having tires bigger/smaller than the original effects your odomter reading
so if i went up to 17" rims, say supra rims, would i have to subract roughly 2.5mm from the I.D.? im not exactly sure how tires are measured.
#4038
20x9 +20 225/30 & 20x10.5 +25 245/30 with rolled rears what will I need to do to fit on a dropped sc400? Already have around -1.5° camber all around.
Someone needs to make a Excel spread sheet because i'm sure many sizes have been asked about over and over but now at 271pgs that's a lot to skim through to find out.
#4039
varrstoens 19x10.5 +0
mounted and floating
![](http://i636.photobucket.com/albums/uu84/redhanded77/IMAG0134.jpg)
control arm jacked up to ride height
![](http://i636.photobucket.com/albums/uu84/redhanded77/IMAG0135.jpg)
prolly gonna go with a 245/35/19 and see what clearance looks like....if I can fit a wider tire, I will. My real te37's are the same sizing.
#4041
haha good question. Long story short, all the cars Ive built (numerious 240's) were all performance based and I actually drive them very hard. Lots of racing and drifting. Ive dented, cracked, curbed and destroyed wayy to much legit rims. Im alot smarter now. When I know Im going to drive hard and have fun, I simply bolt on the rims I can afford to thrash. When Im going to cruise and hard park, I throw on the real ones. Roads here in Hawaii SUCK! Potholes everywhere, freeway included. Ive been in the game long enough to be smart about. I hope you can understand.
#4043
- though I've been in the game long enough to see wheels explode on the track. And yeah, Varrstoens are one of those
Must have missed your post when replying to the other one
#4044
Hey everyone! just got myself a set of Weds Kranze shokis, just wanted to know how much of a pull you think I would need? and any tire size suggestion it came with a 245-45-18 bfg kdw that I am thinking about stretching and also front has 215-45-18 already mounted. Just want to know what everyone else would run
thanks for your input ahead of time. And if any pics please post much appreciated! Thanks
F: 18x10 -18
R:18x11.5 -16
F: 18x10 -18
R:18x11.5 -16
#4045
Must have missed your post when replying to the other one ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Not a fan of 20's, I've only seen one SC on 20's that looked good... anyhoo, the front will probably fit, though you'll probably have to roll it so you can turn. The rear will need a pull, and -1.5 is mild... you might need to go around -2.2-ish for the fender to clear the wheel (not tire, just wheel)
#4046
Here are some pics of what a 19x9.5 +0 with 235/35/19 tire looks like on the rear
![](http://i636.photobucket.com/albums/uu84/redhanded77/IMAG0136.jpg)
Ill have pics later today of what 19x10.5 +0 245/35/19 looks like on the rear. THen Ill take some shots of the front with the said above sizing.
#4047
F: 18x10 -18
R:18x11.5 -16
F: 18x10 -18
R:18x11.5 -16
Unless I'm reading that wrong... is it actually negative 18 and negative 16 offfset?
