Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#436
Originally Posted by nysupraman
well judging from my own wheels and tires, if you dont drop it you should be fine with your fitment. given that the fenders are wider which you said you have. the fronts would be the only problem with stock height. you can run 235/35 or 245's up front, and 275/30 or 285 out back and still be ok. if you drop her that's another story all together, and you should consider fender mods. gluck.
im no expert on wheel fitment, or nearly as knowledgable as the other members on this thread, just my opinion.
#437
Good to see your SC is coming together Cherp, its been a long time coming Aggressive offsets!
#441
19x9 +30 and 19x10.5 +29 wheels... what tire sizes would be optimal for no rubbing? i see cherplex has 275's with about the same offset and width.. would a 265 be fine? i want them to tuck in, but at the same time have a little protection for the wheel because houston roads arent rim friendly
#443
Could anyone tell me if these fit? They're Advan RC2 Bronze Wheels 18X8.5 5X114 +31. I love the look of them in bronze and silver, but I'm not sure of the bore since they're for EVO's and Skyline's. I've got a full Vertex Kit incl. the aero fenders. Thanks!!!
http://cgi.ebay.com/ebaymotors/18-AD...spagenameZWD1V
#444
1UZFE/2JZGTE
#445
Originally Posted by cherplex
Those will fit but with a kit and aero fenders they might look smaller than they are. I would go for staggered 19's.
#446
Well, I'm OK with rolling the fenders, just don't want to pull them.
I've got 1 finger between rim and body, both front and rear.
Still think I can make the +25 17x8.5's work in the front and the +28 17x9.5's work in the rear?
While I want them to be flush, I would rather have them sit a little inside of the fender than for them to extend ANY past the fender.
Any recommendations on tire widths?
I'm thinking of going w/ Falken Azenis RT615 in the front and ST115 in the rear (the 1J eats tires when you get on it )
Thanks
Thanks
#447
CL Member Name: NoLonger A13BFan
Rim Brand and Type: Enkei RPO-1
Rim Size f/r: 18x8.5 & 18x9.5
Rim Offset f/r: 35 & 38
Tire Size f/r: 235/40/18 & 265/35/18
Suspension Setup: Tein Flex Coilovers
Comment On Ride: Ride nicer than the last 2 cars I have had on coilovers
Fender Modifications: No
#449
1UZFE/2JZGTE
Originally Posted by ConSynX
i'd weed through this if i could, i generally search for as much as i can, but i need an answer fast.
curious what offsets to aim for in the front/rear to not need fender modding if i stretch the tires.
20X8.5 and 20X10
20X8.5 and 20X10
#450
1UZFE/2JZGTE
I finally mounted the 19's
CL Member Name:cherplex
Rim Brand and Type: Racing Hart J8's in gold
Rim Size f/r: 19x9 front 19x10.5 Rear
Rim Offset f/r: +26 front +26 rear
Tire Size f/r: 245/35 BFG's 265/30 BFG's
Suspension Setup: Tein H series
Comment On Ride: Firm
Fender Modifications: Rear rolled fronts not done yet
10.5 +26 wasn't as bad as I thought for the rear the BFG's stretched pretty good with lots of meat .
TitanG545 (07-23-20)
