Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#4711
Who did you speak with at Varrstoen? I can't remember his name but one of the customer service reps has an SC and is running 18" x 10.5 +0 all around. I spoke with him on the phone last week. +30 is super weak. I'd get 18"h x 9.5" +12 up front and 18"x10.5 +22 out back if you don't want a pull.
FYI, I'm running 18"x9.5" +12 up front and 18"x 10.5"w +15 out back with 235/40 & 265/35. I rolled and pulled all four corners just slightly, and each side is flush. The rears poke a bit more than I'd like with minimal rubbing on highway divets. The fronts are perfectly fine, no rubbing around hard turns.
#4712
Depends on what kind of a look Biddles is looking to go for and what tire sizes he wants to run.
18x9.5 +30 in the front and 18x10.5 + 30 in the rear is a very nice fitment. Its not week but its not aggressive either. You would be able to run a 255 tire up front and a 275 in the rear and only have to roll you fenders.
#4713
As far as aggressive or weak...I don't really understand that terminology to much. Is aggressive when the wheels stick out past the fender, and weak is when the wheels are too much inside?
If anything I'd like them to be pretty flush.
My car is an automatic, it is the only car I have, it's my daily driver. I'd like it to look cool as ****, but I also need it to be as functional and maintenance free as possible until I get my money up as work is slow right now. I want my tires to last long. As of right now my tires rub...I don't like that at all. I hate it when I got a girl in my car like the other day and every damn bump you can hear the tire rubbing...it's not a good look or a pleasant sound. I'm sure that's mainly because I'm on 20's though. Anyway I hope that helps you help me get a good fit.
#4714
look at post #3265 on page 218 of this thread. its a picture of a 18x10.5 +30 with a 275 tire on it.
yea u have the general idea about aggressive and weak.
as far as your current wheels the reason why u may be rubbing isnt because they are 20s its the offset and tire size you have on. what are the offsets and tire sizes of the wheels you have on right now?
#4715
![](http://i50.tinypic.com/30d80gm.jpg)
Rear Tires
![](http://i45.tinypic.com/icnspw.jpg)
Front Tires
![](http://i46.tinypic.com/9jq2pc.jpg)
![](http://i47.tinypic.com/fegzft.jpg)
I realize my cars dirty, it's been nothing but snowstorm and mud followed by snowstorm and mud over here.
#4716
By the looks of those all you would need to do is roll the fenders flat. As far as which offset for the varstoen wheels take a look @ page 218. Imo 10.5 +30 in the rear and 9.5 +30 would look good.
You should really look through this entire thread to better make a decision. There have been so many combinations already done which would give u a good idea of what will work and look good. I did this when I was getting my volks
#4717
Wow just found about Rimtuck.com....great site gives me pics for every set up.
#4718
My fronts fit pretty on point with -5.1 camber, specs are 18x9.5 0 offset (215/40/18). The rears are a problem though, it pokes about 10mm too much from what I think, specs are 18x10.5 +5 offset 235/40/18). It's sitting about halfway on the tire wall, what do you think?
#4719
That sounds about right. 235s should yield a decent stretch. Haveyou rolled the fenders flat and tested a full load in back? It may tuck nicely. If anything, some burnt rubber as you rub off the lettering on the sidewall
#4720
Just wanted to get advice on fitment on a stock bodied sc300 these specs of wheels 18x9 -4 and 18x10 +0. I rolled the rear fenders flat but haven't touched the fronts a +15 9.5 wheel fits just fine but haven't tried a 9 -4 so advice would help.
thank you in advance
#4721
the front will stick out about an extra 13mm about half an inch compared to the 9.5 +15. your best bet it to just go out there with a ruler and see where ull end up. the rear will require a pull.
i would recommend this to everyone who already has wheels and wants to get another set. Google offset calculator and use one of the sites that come up and enter ur current setup and the new setup ur thinking about. It will give you how much more or less the wheel be compared to ur current set up. after that take a ruler and go out to ur car an measure the difference.
#4723
I think the beginning of this thread should have a base setup. a car that has a flush setup front and rear no poke and not sunken either. just flat rolled/shaved fenders and a drop that has the rear fender in the middle of the tire and the front fender right on the top of the tire but has near 1.5 degrees camber all around and a good alignment. people then could decide higher or lower, or bigger or smaller and how it compares to the base setup.
something like 18x9.5 +20 255/35 rear and 18x8.5 +15 235/40 front. that setup is basically a base.
so say someones asking about some crazy size like 19x10 +0 235/35 front 19x11 +0 255/35 type each in separate wheel (f and r) on the site above and you know if you need more fender work or if you are ok. in the examples case the front will sit about 24mm out of the fender and the rears about 40mm.... so a lot of fender work + more negative camber required. the site give all the details needed.
just a thought...
#4724
just a thought...
just a thought...
The people posting in this thread usually fall into one of 5 categories (some joking ahead; keep your happy face on LOL):
Those Who Genuinely Try: There are the few who actually try to figure wheel fitment on their own; they go through this thread, they research other sources, look at many photos of fitments, take the time to find what they are looking for. They figure out a wheel/tire size and offset, get to that last step, and then just need confirmation on their choices. These people I'll gladly help over the "finish line" because the put the effort into it.
Those Who Think That "Trying" Means Googling It Once: Then there's the one-time searchers who "try" to look, don't find the same setup the first time they type it into Google, nor do they see the same setup in the first 4 pages of this thread. So they decide to just ask because OMG it's taking way longer than 3 minutes to figure it out
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Those Who Go Ghetto Custom: Then there's the "I want to get cheap used wheels that come in really bad/wrong offsets that don't fit the car, but I want them anyways because they're cheap so tell me what I need to do to make it fit" people
Those Who Believe in Bigfoot: Then there's the "I want hella-flush-JDM-VIP-fitment slammed to the ground Illest yo-style... but I don't want to do ANYTHING to my fenders and I don't want to change ANY alignment specs" people. Yeah, it's that easy
Those Who Have Issues With Imagining a 2mm Difference: Then there's the "I'm looking at a 18x8.5 +22 wheel. There's a photo in this thread of an 18x8.5 +20 wheel. So it's not the same - will my wheel fit?" people
There are already a lot of different "base" setups with photos throughout this thread. Most of the new wheel questions could have been answered on their own if they just put the time into looking through the thread - but usually they don't look first, no matter how many times you suggest it LOL
#4725
