SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 05-21-13, 07:17 PM
  #4861
OhHiChris
OhHiChris's Avatar
Old 05-21-13, 07:30 PM
  #4862
6SOARER
6SOARER's Avatar
Originally Posted by raine
265/30 and 225/35 should be about right
Thanks, would you think 40's profile would be too much? I'm thinking 30s are too low profile, I want a lil more ride comfort
maybe 265/35R 225/40F ?
Old 05-22-13, 10:17 AM
  #4863
Handsome
Handsome's Avatar
Hi,
I'm new to the SC game. Just got a SC400 and I have a set of 18x10's to through on the back from my Z. My question is will a 225/50 tire work? Thanks for the help.
Old 05-22-13, 09:19 PM
  #4864
durps
durps's Avatar
^Yes it will work. Will give you a mild stretch.
Old 05-22-13, 10:31 PM
  #4865
golf007
golf007's Avatar
Need help with the new set up please , just got the mesh wheel by weds 18x9.5 +47 an 1.5 lip size. then changed the lip to 3.5" so now is 18x11.5 +47 ( same offset since I changed only the lip not the inner barrel )
1. Will it fit on rear of SC 400 with stock camber ? Got the TEIN coilover n fender are rolled
2. 265/35/18 will this size be okay with those lip size?
Thank you in advance
Here is some pix, getting idea how it look like
Old 05-23-13, 05:36 AM
  #4866
MDSC
MDSC's Avatar
^ you did change the offset by putting a different outer barrel on the wheel. Yes the wheel wont move closer or further away from the body it self but offset is where the actual face in reference to the center of the barrel. So your face before was 47mm front the center towards the outside of the car now your face will be sunk 3" towards the inside of the car. So to answer your question no 11.5 -3 will not fit a stock body Sc not even close your rim will stick out about an inch past the qtr panel.
Old 05-23-13, 05:42 AM
  #4867
MDSC
MDSC's Avatar
Originally Posted by Tabaka
So I've been thinking about getting Origin 25mm fenders lately. I currently have 18"x9.5"+12 and 18"x10.5"+15.
This is what I'd like to do.
I want to put the rear 10.5"s up front, and purchase two more wheels for the back.
This is the crazy part, I want 19"x10.5"+15 in the rear with the 18"s up front. This will give it a better rake look and fill up the rear wheel well.
What does everyone think? I've seen it done before on RX7's, which have smaller wheels up front and larger diameter wheels in the rear. Will the 18"x10.5" +15 with 25mm Origin fenders fit ok, clear BBK's, etc?
first of sc already has a rake if lowered evenly, look at the body line and where the wheel well cut out in the back compared to the front.i'm 100% against different size wheels but its your choice obviously.Making the car fit the wheels is easy making the wheels fit the car is the hard part.
Old 05-23-13, 12:25 PM
  #4868
CalitriSC
CalitriSC's Avatar
I have never been a fan of the 18/19 set up on an SC. From the side profile the fronts will look small and then you have to pretty much tuck rim in the rear to match the front height. It looks awkward to me, but its up to you lol..
Old 05-23-13, 01:27 PM
  #4869
Handsome
Handsome's Avatar
Have some XXR 521's in 18x10, what tire should I run in the back that won't require me to mod the fenders? Car isn't lowered yet.
Old 05-24-13, 06:56 AM
  #4870
Tam4511
Tam4511's Avatar
I want to run 18x9.5 in the front and 18x10 in the back. I'm wanting more of a battle stance, where the wheels poke out just a tad and fits nice in the fender (witha roll obviously) what offset would I need?
Old 05-24-13, 07:45 AM
  #4871
golf007
golf007's Avatar
So in order to make it fit , I ll need to pull the fender n do negative camber a little ? Thank you for the info MDSC
Old 05-27-13, 05:42 PM
  #4872
Studiogeek
Studiogeek's Avatar
Question
Greetings,
I have a set of WORK VS-ZF. Sizes are:
255/35/ZR18 8.5 (?)
285/35/ZR18 9.5 (+45)
I am currently stock (but drooping in rear) height. I have not rubbed at all yet.
I am going to re-lip the Works over the winter, but I will run spacers until then.
I just ordered 38mm bolt on, hub-centric spacers.
I will add coilovers for a moderate, tasteful drop in one month or less.
These pictures are how it sits now, before spacers and drop.
What should I expect when I put the spacers on? I am prepared for roll/shave whatever is best.
How should I expect the fit to be? Stock and dropped.
Thanks in advance !!!
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-2fit2-.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-fit4-.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-fit5.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-2fit3.jpg
Old 05-28-13, 02:37 PM
  #4873
sc400fb
sc400fb's Avatar
Hey what's up I have a question I getting 18x8 front and 18x9 rear 40+ offset and will lower it a lil won't slam it what is the widest and lowest profile I can use for tires on my 96 sc400 thank you for any info u give me Lee
Old 05-29-13, 10:48 AM
  #4874
jadu
live.love.laugh.lexus
jadu's Avatar
The widest I'd probably go is 245/40/18s for the fronts and 275/35/18 for the rears
Old 05-29-13, 10:51 AM
  #4875
jadu
jadu's Avatar
Originally Posted by Studiogeek
Greetings,
255/35/ZR18 8.5 (?)
You will have 38mm more poke! Take a ruler to your wheel to help you visualize that's what I did when I did my calculations for relipping just before I ordered my lips
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
