SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 01-04-15, 06:38 PM
  #5476
Rickbean
Rickbean's Avatar
Another pic of them. I'm ordering some spacers to flush them. They look like crap IMO
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-image.jpg
Old 01-06-15, 12:15 AM
  #5477
bilgen
bilgen's Avatar
Just need moar low and about 15mm spacers. Those could look great if you get the stance dialed in
Old 01-06-15, 11:30 AM
  #5478
DerekJZZ30
DerekJZZ30's Avatar
18x10 +2 19x11 +9 OEM Arms all around. Stance Coilovers w/ Swift Springs 30k 24k Re Valved
Work Gnosis GS2<br/>18x10J +2 - 19x11J +9<br/>Stance Coilovers Re-Valved W/ Swift 30K 24K<br/>OEM Arms Maxed Out Camber & Toe
18x10J +2 OEM Arms.
Old 01-23-15, 04:30 PM
  #5479
GregRedSc3
GregRedSc3's Avatar
Default need help on tire sizes
hey guys,
I have purchased a set jnc019 which are 18x8+27 for the front and a 18x9 +25 for the rear. based on the fitment chart I have looked at both the front and rear fit without fender modification. what size tires should I run
Old 01-24-15, 07:25 PM
  #5480
GregRedSc3
GregRedSc3's Avatar
Default need help with tire sizes asap
Originally Posted by GregRedSc3
hey guys,
Wheels will be here Tuesday any help is appreciated, by the way I am lowered 1.5 inches all around and am planning to get coilovers next, thanks for any help
Old 01-26-15, 10:36 PM
  #5481
durps
durps's Avatar
Hey guys, how would (F)19x10 +29 Med Disk (R)19x11 +24 Super Low Disk fit? Im planning on going low as can be without being slammed, if that makes sense lol. Just decently low. Might be adding a 5mm spacer to the front to clear my LS calipers.
Old 01-27-15, 12:58 PM
  #5482
t2d2
t2d2's Avatar
I just put 17x9 +24 wheels in back and they're perfectly flush. Yours at 2" wider and the same offset would presumably extend out an inch to either side of the shared center line, so you'd probably need to pull the fenders an inch?
I can't imagine you would need a spacer in front with a 10" wheel and that low of offset, unless the spoke design is crazy. At +29, you kinda sorta picked up the equivalent of a 20mm spacer, and 15mm should be enough to clear LS calipers with stock offset wheels.
Old 01-28-15, 06:50 PM
  #5483
CatManD3W
CatManD3W's Avatar
My wheel and tire specs.......XXR 521 18x8.5 +25 w/ 245/35/18 & 18x10 +25 w/275/35/18
I have all four corners rolled completely flat and I am on coilovers......I still need to adjust coils a little bit to go lower...but have about a 2 finger gap all around
The fronts could use a 10 mm spacer to make it have a little poke like the rear.....they clear LS400 BBK with ease...and will most likely go with a 255/35/18 next
The rear are perfect......they do not rub at all...I may do a pull to fit 295/35/18 later on
The car has been parked for winter but I will get some newer photos with coils adjusted and 10mm spacers up front added once winter breaks...
Old 01-28-15, 08:38 PM
  #5484
InLyneTrbo
InLyneTrbo's Avatar
Right now, I'm running XXR 531s with 18x11 +20 in the rear. There is a little too much poke for my taste. Sorry for the bad pics, this was a while back and only had my phone on me at the time:
I am looking at the Cosmis Racing S5Rs that come in 18x10.5 +20. I want to be able to run a 295 or even 305 tire if possible as I'm already having major traction issues with my setup and it's only a stock 2JZGTE lol
Is 1/2" less in width a pretty decent/noticeable difference? I want the wheel to tuck back in closer to the fender, and am hoping that 1/2" will make that difference. And also, should I have any trouble running a 295 or 305?
Old 01-28-15, 09:26 PM
  #5485
kksc300
kksc300's Avatar
Default New wheels
Hi There! Thats my first post and it's about new wheels.I'm looking to buy 18x8 +35 235/40 front and 18x9 +35 265/40 rear.My question is will i need to roll my fenders or i can run them like that with stock suspension?
Old 01-29-15, 12:09 PM
  #5486
Sc400NL
Sc400NL's Avatar
hello
much has been written about wheels and tires and i had many help with the PM's some of you send me
but i would like a final advice about the choice of tires
Falken are widely available in Europe but not as common so i don't have reviews on those , but its all about the side walls of the tires
i'm thinking Falken (what type? ) toyo proxes t1 or michelin pilot sport
for these wheels
2 X 8.5 X 19" 5X114 ET38 ALLOY WHEELS (FRONT)
2 X 9.5 X 19" 5X114 ET35 ALLOY WHEELS (REAR)
a bit of rolling is no problem , pulling is
i want to go for the box like look , no stretch or balloon like shape
like this but then in 19 inch
what sizes do you advice for these wheels ?
245/40/19 front and 275/30/19 in the back , or 265/35/19 ...so many choices to make
Old 02-02-15, 09:22 PM
  #5487
irondonkey
irondonkey's Avatar
anyone running a 255/45 tire on a 11 inch wheel?
i feel like my tires may be too tall for the rear...
they were free :\
Old 02-03-15, 09:03 AM
  #5488
jadu
live.love.laugh.lexus
jadu's Avatar
they were free :\
depends on the diameter. 255/40/R18 is the stock IS350 rear wheel tire and I think that's tall, so a 45 series is 5% taller. I'm running 255/35/R18 in the rear and that's plenty tall enough for me.
Old 02-03-15, 09:16 AM
  #5489
jadu
jadu's Avatar
Originally Posted by Sc400NL
hello
for these wheels
Yes, there are quite a bit of tire choices. Some ride too wide, some run too narrow, so I know how you feel. For the fronts, I would go with 245/35/R19 for the 8.5 inch wheels. These should not look stretched nor ballooned. For the rears, 275/30/R19 and these should also not look stretched nor ballooned on the 9.5" rears.
Old 02-03-15, 09:22 AM
  #5490
jadu
jadu's Avatar
First off welcome to ClubLexus. This setup would clear the fenders at stock suspension. I don't think you'll need to roll any fenders
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
