SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 01-07-16, 07:47 AM
  #5641
myLEXsc400
myLEXsc400's Avatar
So I just picked up my first set of "REAL" wheels. A custom set of stepped lip Work VS-KF's
18x9 +20 and 18x10 +20
the fronts dont fit my bbk so i need 10mm spacers
Wheels poke a bit, and my fenders are not pulled, just rolled. I plan on running 245/40 in front and 255/40 in rear.
I'm running lance spec alignment, so no big camber. Will this work without rubbing? I'm on coilovers. Height pic for reference
Old 01-08-16, 08:55 AM
  #5642
Blkexcoupe
Blkexcoupe's Avatar
18x9 +25 and 18x10 +22
I think it'll fit fine. You might rub going up driveways or a hard bump, but that depends on your coilover stiffness and how flat your fenders are.
Old 01-11-16, 04:23 PM
  #5643
myLEXsc400
myLEXsc400's Avatar
Originally Posted by PlanB
Hi guys, I have 18x9 +10 225/40/18 in the front, 18x10.5 +25 255/40/18 in the rear. I'm ok with the front, but dont like the rear because the tires kinda stretch too much. Is it fine if I run 275/35 or even 285/35 ? My fenders are rolled not pulled. Thanks
Do you have pics of your fitment? I have a set of wheels, 18x9 +10 and 18x10+20, and wondering if they will fit the car with just a fender roll. DO you have any pics of your car?
Do your wheels rub with your setup? Are your fenders rolled and pulled or just rolled?
Im thinking of going with 235/40 and 265/35
Old 01-16-16, 07:39 PM
  #5644
MrCJ305
MrCJ305's Avatar
Anyone running 19x10.5 +25 up front?
Old 01-21-16, 06:34 PM
  #5645
kitsune
kitsune's Avatar
Originally Posted by OhHiChris
It will fit if you know what you are doing. I'm running 19x9.5 +19 and 19x11 +19. Stretch tires and have a decent amount of camber.
This was before I pulled my quarter panels, it is just rolled flat in these pictures. (I'm on air btw)
Are you running a BBK?
I have 6 pot fronts and 4 pots rears
might need to dish out some money for some HRE's
Old 01-26-16, 08:13 PM
  #5646
scmaluco
scmaluco's Avatar
Anyone running Esr sr02 wheels on their sc? Pics would be great.
Old 01-27-16, 02:23 AM
  #5647
PlanB
PlanB's Avatar
would 285/35 work on 18x10.5 offset 30 with rolled fender, I know 275 should work but not sure about 285
Old 01-29-16, 10:45 AM
  #5648
Kris9884
Kris9884's Avatar
Originally Posted by Blkexcoupe
I drove a SC with a 19x10.5 +23 with 265/30/19 advan tires. The rear fender was completely shaved and it would rub if i turned too fast. I think the camber was around -2 to -2.5, but if you're willing to add more negative camber, then it won't be an issue.
My current SC is 18x10.5 +36 with a 285/35/18 Michelin Pilot Sport, shaved rear fenders, -1.9 degrees of camber and I have no issues with it rubbing. If I put a 5mm spacer it'll rub the rear fender on dips.
Could you post a picture of the rear fender and wheel fitment? I'm looking at a set of Volks with +38 18x10.5 and wanna see how they look. I'll love you long time.
Old 01-30-16, 07:39 AM
  #5649
Blkexcoupe
Blkexcoupe's Avatar
Pictures of it dumped
My rear fender still has a slight lip, If it was completely flat I could go with lower offsets or wider tires.
Old 02-01-16, 02:11 PM
  #5650
GTX580
GTX580's Avatar
Anyone running 20x11 in the rear?
Old 02-03-16, 09:30 AM
  #5651
Kris9884
Kris9884's Avatar
Awesome thanks man.
Old 02-10-16, 10:25 AM
  #5652
zmds18
zmds18's Avatar
On route, should be here in a few weeks O.Z. Vela II
18x8.5 +37 18x10 +38
Old 02-19-16, 10:23 AM
  #5653
jwynn
jwynn's Avatar
Default Would 20X8.5/20X10 44/46OFFSET
Anyone know if 20X8.5/20X10 44/46OFFSET Would fit without mods? with maybe a 20/35/225 and 245 stretched tires.
Old 02-19-16, 10:25 AM
  #5654
zmds18
zmds18's Avatar
Did you even read the very first post?
Gamer
front: rim size 18x9; offset +44; tire size 245/45/18; no fender modifications
rear: rim size 18x10; offset +49; tire size 265/35/18; no fender modifications
Old 02-19-16, 11:11 AM
  #5655
jwynn
jwynn's Avatar
Gamer
Yes....... its a 20 inch rim I'm asking if it fits bc its not 18inches..
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
