SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 07-14-06, 07:45 AM
  #556
JoshFSM
JoshFSM's Avatar
Originally Posted by TurboTeg
The specs were chosen with stretched tires in mind. I'd like to see how the flares turn out. Good luck!
Im aware, although at least the rears would have beein in the ball park I wanted to accept a tir of this girth. Im playing with weight transfer and suspension travel in the rear to hopefuly make everything work. Will keep yall posted on the flares
Thanks!
Old 07-15-06, 06:01 PM
  #557
WebStarr
WebStarr's Avatar
Thanks!
Another good idea might be to have some of the pad shaved off if you don't plan on using big brakes. That will push the wheel more inboard.
Old 07-15-06, 06:49 PM
  #558
ConSynX
ConSynX's Avatar
the test fit
these are 18X9.5 +20
not sure how much tuck i'm gonna get when the car's dropped on them
going to try 235/40s on it first, if not then maybe 225/45
also rolling fenders, drrrr
Old 07-15-06, 07:36 PM
  #559
jibbby
Banned - could not follow forum rules
jibbby's Avatar
Your ruined when the tire and rim stick out past the fenders....There is a fine line between awesome and discusting....Becareful....
Old 07-16-06, 01:30 PM
  #560
lsflame
lsflame's Avatar
Read the whole post on wheel fitment. There are even wilder setups than that. Look at Monghol-Khan and TurboTeg or or even Workaholic. My wheels fit almost as wild as his with 9.5 +25. You wouldn't know what flush fitment is if i did it for you. In all honesty you do you stick the tire and rim slightly past the fenders and then you run negative camber and a stretched to fill out the wheel wells.
Old 07-16-06, 04:01 PM
  #561
jibbby
jibbby's Avatar
Read the whole post are you nuts? That would take me a whole day...Besides I know the sizes and fits of all tires in the SC's...I've tried Supra big brake swaps, widened and altered rear rims etc... When my wheels stuck out I almost puked...
I fitted the widest tire that can possibly fit in the rear wheel wells without curling the lip...275/35/ZR18's.....Any wider and I would scrap either the rear shock or fender lip.... I speak from experience....
Unless you have custum made extended fender effects stick outs stink...Unless your a chollo I don't think it works) Just my opininon, everyone has different tastes...
This is not a good pic, but it is the only one I have...the tire extends to the lip edge...
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-hpim0435b.jpg
Old 07-16-06, 04:03 PM
  #562
jibbby
jibbby's Avatar
One more pic....
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-picture-122.jpg
Old 07-20-06, 03:09 AM
  #563
Sc400on20s
Sc400on20s's Avatar
CL Member Name: Sc400on20s
Rim Brand and Type: Lowenhart LS-1
Rim Size f/r: 20x8.5 / 20x10
Rim Offset f/r: +42 / +45
Tire Size f/r: 245/35/20 / 275/30/20
Suspension Setup: Eibach Pro Kit
Comment On Ride: Smooth but stiff
Fender Modifications: Rear fenders rolled
Any other comments: none
Rim Brand and Type: SSR Minervas
Rim Size f/r: 19x9.5 / 19x10.5
Rim Offset f/r: +43 / +43
Rim Brand and Type: L Sportline MIV
Rim Size f/r: 20x8.5 / 20x9.5
Rim Offset f/r: +45 / +43
Suspension Setup: JIC coilovers
Comment On Ride: Stiff
Fender Modifications: Rolled front fenders
TitanG545 (07-25-20)
Old 07-20-06, 06:52 AM
  #564
Batmobile
Batmobile's Avatar
i like.......
Old 07-20-06, 02:07 PM
  #565
jefferino
jefferino's Avatar
Okay so I searched EVERY page of this thread. I called Volk who said they dont have the wheels I want that will fit...obviously because they are being conservative. In any case, can you guys lend some help...I really dont want to roll or have to shave much if any but would like as big a lip as possible. I am on Buddy Club Coilovers so I would obviously have it lowered a bit also. Below are the front and rears and available offsets. Thanks for ANY and ALL help!
REAR
19x9.5
+43,+28,+4,+17,+5,+30,+40,+23,+53,+37,+14,+49
FRONT
19x8.5
+43,+46,+24,+30,+21,+36,+34,+11
Thanks again!
Old 07-20-06, 02:13 PM
  #566
ACleanSC4
ACleanSC4's Avatar
REAR
19x9.5
FRONT
19x8.5
Thanks again!
I say fronts +11 (roll fenders) or +21...
rears = +23 or +30 to play it safe...
Tire sizes fronts, 225 or 235's...
rears = 245's, maybe 255 or 265...
Be sure to lower it at least to the tire or else it'll be poking out..
My setup is 19x8.5 +15 (I can probably go out at least another 5-10 mm...)
Rears are 19x10 +30...i posted pix here so check them out so you see where yours will sit...
https://www.clublexus.com/forums/sho...&postcount=221
Old 07-27-06, 10:44 AM
  #567
Revolt!!!
Revolt!!!'s Avatar
CL Member Name: Revolt!!!
Rim Brand and Type: TSW Catalunya Hyper Black
Rim Size f/r: F:19x8 R:19x9.5
Rim Offset f/r: F:+40 R:+37
Tire Size f/r: F:245/35/19 R:275/30/19
Suspension Setup: Tokico / Eibach Pro
I did have some light rubbing in the rear so i rolled the fenders.
Old 07-27-06, 11:30 AM
  #568
Splatsc300
Splatsc300's Avatar
His wheels arent even that bad. Maybe you should read the whole thread, or just look at the pics. If everyone has different tastes maybe you shouldnt have made the comment "Your ruined when the tire and rim stick out past the fenders....There is a fine line between awesome and discusting....Becareful...." AND MAYBE you shouldnt use a word like cholo some people might find that offensive.
Old 07-27-06, 01:14 PM
  #569
Shrummi
Shrummi's Avatar
if i go with 19x8.5 and 19x9.5 with a 45+offset and for tires with 225.35.19 for front and 245.35.19 for the rear. Will i need to roll the fenders??? they will be riding on tein flex coilovers. i think they have less offset if that helps but if anyone could help me with that it would be appreciated thanks.so i don't buy rims and regret.
Old 07-27-06, 02:49 PM
  #570
plex
1UZFE/2JZGTE
plex's Avatar
With those offsets I don't think you need to run stretched tires to make them fit. You might need a slight roll depending on your drop.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
