Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#5761
Depends on the year.... '92s started out as 15 inch. Not sure when the "stock" wheel went to 16 inch. I would not recommended 17s only because the tire selections can be limited. 18 is a better choice. 19s and 20s come with other challenges driven by the fit one may be looking for....
#5762
Figured out what wheel style I want and I found them in:
18x8.5 +30 Front
18x9.5 +35 Rear
My suspension is stock at the moment, do you think this set up is doable? I figure I may have to roll my fenders.
18x8.5 +30 Front
18x9.5 +35 Rear
#5763
#5769
#5770
What are the offsets? I do not like 17s.... If you are going to go for larger wheels go to 18s at least. Hub rings are problematic, too, so likely these are 70mm where the small Lexus hubs are 60.1mm (and a hub ring is recommended but there is a lot of discussion on which ones work best and are safe). I'd keep looking but research the offsets to get the fit you want.
#5772
Looks like I'll be going Enkei RPF1's 18x9.5 +15 on front and rears with 245/40/18. Do you guys think I could squeeze 250/40/18 on the front and rear for beefier tires? Also, will I clear with just rolling my fenders all around?
#5773
What are the biggest drag tires the SC300 can fit without fender modifications? I see that on the first page it looks like 245 front and 265 rear, but that's with 18s. I'm looking at MT ET Street tires in 15" and 16" sizes. I'm assuming wheel size effects that but I don't know much about this stuff. Any help would be appreciated.
#5774
Here is my setup.
Wheels : LM Reps
19x8.5 F +15
19x9.5 R +20
215/35/19
245/35/19
Front and rear fenders are rolled. Depending on the rim choice, 19s can look big or just right. My LM reps and real things like BBS or Works have a step lip. So 19s look more 18s with the step lip type. 19s without a lip can look pretty big on the car. All depends on your style. 19s with a staggered setup with the right offset looks pretty mean. My offset sits pretty flush with the fender. If you go big and low you will have to roll the fender and run a stretched tire. So think about ride and performance loss possibly in order to achieve the look you want. I personally wouldn't run anything smaller then 18s, but tend to lean toward 19s.
#5775
Here is my setup.
Wheels : LM Reps
19x8.5 F +15
19x9.5 R +20
215/35/19
245/35/19
Wheels : LM Reps
19x8.5 F +15
19x9.5 R +20
215/35/19
245/35/19
