Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#6078
I’m assuming the next 18x10.5 +49 O-disk will cause all sorts of inner rubbing?
I don’t want to do heavy guard mods, just a simple roll. My other options are 18x10 +43 O-disk for a beefier tyre fitment which is what I’m after. Or 18x10.5 +41 A-disk...
#6079
美少女戦士セーラームーン
I would say a higher offset in the upper 30’s or 40’s might work but you may need to roll the fenders.
#6080
Any pictures of Meisters fitted in a similar spec?
10.5 +49 o disk will fit with clearance inside. I think you could get away with no fender mods depending on tire size and ride height.
*Edit*
My wheels in this photo are:
F: 18x9.5+27 245/40/18
R: 18x10.5+36 275/35/18
#6082
美少女戦士セーラームーン
I don't have any pictures of meisters in that spec, but 18x10.5 +37 O disk is the spec I'll be ordering when its time for me to order meisters.
*Edit*
*Edit*
#6083
Just picked up a '97 SC300 with 15 year old tires on it. Need some guidance on wheel/tire options.
Still looking at wheels but based on what I gathered from this thread, can you guys confirm this is good for stock height:
18x8-8.5" with +45 down to +35mm offset
245/40/18 for square setup
Is this good enough to get the wheels more flush with the fenders ? What would be a good tire size if I do staggered ? Will be on stock heigh for some time so I don't want anything too agressive.
#6084
CL Member Name: Rozay
Rim Brand and Type: Maserati Quattrocento Wheels
Rim Size f/r: 19x8.5/19x10.5
Rim Offset f/r: +52/+50 (Spacers Needed)
Tire Size f/r: 225/40/19? 245/40/19? (Should I go wider?)
Suspension Setup: Bc Coils 12k front 10k rear
Comment On Ride: Trying to get an idea on what I should do about the offset. I got 20/25mm spacers to make it +27/+30 but im not sure.
Fender Modifications: Probably haha
Any other comments: Should I put the ARP studs on the spacer or on the hub?
Thanks In Advanced For Any Help
#6087
Shayy and 1of120 out here makin me feel some kind of way!!
Shayy (01-14-21)
#6088
I know I may come off repetitive, but I recently bought 18x8 +45 offset, squared setup of work varianza t1s and the seller said they were low disk, will it clear my OEM front calipers for a 1999 Lexus SC300? Will I need spacers, if so, any recommendations and what size? Thanks for your feedback in advance!
#6089
The wheels will fit. However, you may opt for spacers simply to make them look more flush. At stock height, a 15mm spacer should make the wheels look more flush.
onizukhoa (01-15-21)
#6090
Ah, so they will fit with low disk. Thank you for your input! I'm tryna run the setup without spacers, only need it if have brake clearance problem!
