Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#6106
1993 SC300 5MT
CL Member Name: Turbostar
Rim Brand and Type: ESR SR05
Rim Size f/r: Front: 18 x 8.5; Rear: 18 x 9.5
Rim Offset f/r: Front +30; Rear +35
Tire Size f/r: Front 245/40R18; Rear 275/35/R18
Suspension Setup: BC Racing Coilovers, set how they came right out of the box
Fender Modifications: None
Any other comments: I would need to roll fenders if I want to go any lower
Picture:
Picture:
#6107
I’ve only seen sizes like that on wide body SC’s.
#6108
1992 sc400 . time for new rims and tires
lots of old threads regarding this subject and very informative.
I just want to go to 18 inch rims and 245/45 18 Potenzas... anybody have nice ideas for rims I can get ? Im 70 and old school. Kinda like chrome.
clayface (07-28-24)
#6109
I ran the OEM 2004-2006 LS430 18 inch wheels in that exact tire size on my SC300 for years. Mine were chrome as well. I would highly recommend those or the 2006-2011 GS 18 inch wheels. They look good with this tire size and it’s a smooth ride.
#6111
Or do you mean old school like classic Japanese, or era correct? Lots of options out there. I just went through a lot of time looking at wheels, and I first narrowed it down to the general "look" I liked. Thinner spokes, or fatter spokes? Or no spokes? You already know you like chrome, so that narrows it down a lot. I also wanted to go with chrome (I'm old school too, classic cars), but after seeing what was available in chrome, I had to go another choice.
What I did that really helped was just put "sc300 wheels" or something like that into google, and just look at image results. Also there are several large wheel websites that all use a similar wheel selector interface. It is very helpful, and updates in real time based on the options you select. I'm not sure if it is against forum rules to link a website so I won't, but PM me if you want to know.
Go to those websites and play around with the selector. First filter by bolt pattern, then by size, then by finish, etc... until you see what is available.
#6112
I've been up and down this thread but haven't found an exact numbers. Currently running 18x8 +35 with 225\40 FR 245\45 RR
I'm looking at some 18X8.5 FR 18X10 RR +20 wheels. Will be installing ls400 bbk soon. Any recommendations on tire sizes? Will offset be an issue? I'm on maxpeeding coilovers, not lowered a ton. I don't mind rolling fenders🤏, but cutting is a negative pls👎
#6113
Need help with fitment.
I have a 1993 sc400 and was looking at
Front wheel 18/8.5 + 35
Rear wheel 18/9.5 + 35
Front tire 225/40zr18
Rear tire 245/40zr18
Need to know if this will be good lmao😂
#6114
putting a really big BBK on my SC300 @ stock ride height. I know I need at minimum 18s, which is what ill go with. but if anyone has any help with sizing wheels for cherokee srt8 brembos I'd appreciate offset, diameter, width and tire size measurements. thank you.
#6115
Thank u
Offsets given are as follows....
9 1/2 width
Disk A______Disk B
+3________+11
+15_______+23
+28_______+36
+40_______+48
10 1/2 width
Disk A_______Disk B
-17________-9
+3________+11
+15 ______ +23
+28 ______ +36
Dosen't show what you suggested so i'll assume your kidding. Thanks though for trying to help.Edited for clarity.
9 1/2 width
Disk A______Disk B
+3________+11
+15_______+23
+28_______+36
+40_______+48
10 1/2 width
Disk A_______Disk B
-17________-9
+3________+11
+15 ______ +23
+28 ______ +36
Very helpful as i am looking for "Real" wheels and tires ..worl meisters
#6116
CV3-R 19's ? for 95 SC400
Hi guys,
I have a chance at buying some Vossen CV3-R wheels - they are
19x8.5 +14mm offset for the fronts and
19x10 +10mm offset for the rears
Will these fit if i have coilovers and will get my fenders rolled/pulled? What I'm most worried about is the offsets. Usually the offsets are between 32 and 40 for 19's on SC's.
This is how the SC400 looks with these rims on. His offsets are in the +20s/30s range from what i remember reading.
Anyway - the reason why I believe the rims will fit is due to this car below and its offsets:
1998 Lexus SC400 Base
Work Meister Front: 19x8.5 +12 Rear: 19x9.5 +10 | Bridgestone Potenza Re050 Front: 235/35 Rear: 255/35 | BC Racing Coilovers
Please let me know what you guys think? I could really use the help here.
Thanks
Thanks
TitanG545 (03-17-22)
#6117
Hi guys,
Thanks
Thanks
#6118
Hey all!
What are opinions on 18x9 +35 with 245/40 all around? I am wanting to keep a square setup.
Will this give me too much poke on the front? I am okay with adding spacers anywhere that they’re needed.
I have a 97 sc400, currently on stock suspension. My fenders are not rolled. Have plans to lower it slightly later on in the year but would like to put off fender rolling until then.
Thanks everyone!
Thanks everyone!
#6119
Hey all!
Thanks everyone!
Thanks everyone!
#6120
Stock wheels w spacers
For people like me who were looking for this specifically. Here is stock 16” wheels with 25mm spacers on front and back. Stock suspension.
With spacer
With spacer
With spacer
Left spacer right no spacer
Stock no spacer
Stock no spacer
With spacer
With spacer
With spacer
Stock no spacer
Stock no spacer
Kira X (02-10-22)
