Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
- IS ES GS: Lowering Modifications
Important information to help you understand your Lexus
- How to Mount a Tire to your Rim
Step by step instructions for do-it-yourself repairs
- Tires General Information and Specs
****Official Wheel & Tire Fitment Guide for SC300/SC400****
#601
Thanks for the quick response guys.
I'd just did a quick test fit of the rims on the car and the front don't appear to fit. I was told I can shave a little off the brake pads, would getting spacers be advised at this point? If so, how much spacing would I need and would it also be recommended that I get spacers for the rears to keep the ratio even with the fronts? The rears fit without any issues by the way.
even if you ran a small spacer, that's only going to make the wheels stick out farther... I just wouldn't do it...
#602
hey guys i need some advice
im on 19x8.5,19x9.5 255/35/19 275/30/19. i just bought some tokico blues and was thinking about gettin some eibach prokit. do you guys think the drop will look good or is the gap gonna be too big? i dont want espelirs cuz i dont wanna get a camber kit or crack my paint when the fender roll
thanks
thanks
#603
My contribution:
CL Member Name: TopSCecreT
Rim Brand and Type: Racing Hart CX multi-piece
Rim Size f/r: 19x8.5 Front 19.10 Rear
Rim Offset f/r: +37 Front (high disk) +42 Rear (low disk)
Tire Size f/r: 245/35 Front 275/30 Rear
Suspension Setup: Tein CS coilovers
Comment On Ride: No complaints on the ride, the SO-3 are quiet.....but overall good ride
Fender Modifications: Shaved rear fenders
Any other comments: My coilovers are set at the lowest drop, so when i turn the wheel all the way or corner pretty roughly, i rub
Picture:
![](https://www.clublexus.com/gallery/data/500/10789DSC00626-med.JPG)
![](https://www.clublexus.com/gallery/data/500/medium/10789DSC00626.JPG)
Picture:
Looks really nice !
#606
thanks
thanks
check out sig for pic...
#607
mine looks perfect IMO... I also have very close sizes to yours, but 18" up front...
hey i think thats a perfect drop also.Now you have the supra teins or sc teins?
also wuts the name of the teins?i wonder if my front will rub cuz i have 19s tho.did you do any fender rolling?camber kits?alignment?
#608
no camber kit, but I did the "performance" alignment - slightly more camber than stock, but still reasonable: -1.75 rear, -1.5 front... i have +35 offset (9.5" wheel) in the rear, and I did have to roll the fenders to make it work... on the front, there is a ton of room, and I have 8" wheel with +40 offset... Although I am normally against them, I am thinking about doing a 5mm spacer up front to set it out a little farther... I really think on a little wider wheel, I could fit a wider tire too...
#610
19x10 w/ 20 offset front and rears
front tires: 235/35/19 front fenders rolled and pulled just a lil bit
rear tires are 245/35/19 rears just rolled.
car is dropped alot and the wheels were sticking out about an inch past before it was lowered and it cambered in quite nicely
![Name: f2pic7.jpg
Size: 68.8 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/441347d1501411301-official-wheel-and-tire-fitment-guide-for-sc300-sc400-f2pic7.jpg)
![Name: f2pic2.jpg
Size: 69.7 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/441348d1501411301-official-wheel-and-tire-fitment-guide-for-sc300-sc400-f2pic2.jpg)
![Name: f2pic.jpg
Size: 69.4 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/441349d1501411301-official-wheel-and-tire-fitment-guide-for-sc300-sc400-f2pic.jpg)
wheni first installed hte coilovers i didnt know how low to set it so it was dumped
it tucked alot for it being a 19x10 with a +20
![Name: scslam4.jpg
Size: 47.2 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/441350d1501411301-official-wheel-and-tire-fitment-guide-for-sc300-sc400-scslam4.jpg)
![Name: f2pic7.jpg
![Name: f2pic2.jpg
![Name: f2pic.jpg
![Name: scslam4.jpg
![Name: scslam.jpg
Size: 68.8 KB](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/441351d1501411301-official-wheel-and-tire-fitment-guide-for-sc300-sc400-scslam.jpg)
TitanG545 (07-25-20)
